樓主: chai87
newbie in rc boat
 樓主| 發表於 2009年6月14日 12:40 AM | 顯示全部樓層
no one can  me???some one who know  english can answer me??
發表於 2009年6月18日 01:28 AM | 顯示全部樓層
為什麽要用三個燃料箱?這樣會引致氣壓不夠!機器不夠燃料供應而損壞了!
IIs Shi? Have damaged to so draw with 3 fuel cases to deliver the insufficient machine insufficient fuel supply of atmospheric pressure
我是使用翻譯機的!
 樓主| 發表於 2009年6月21日 03:41 PM | 顯示全部樓層
sorry...c.k.y..u misunderstood me..i mean i only break in with 3 tanks of fuel..i have problem with start the engine..hard to pull.what is the setting of the carbureator??the pull start so hard to pull,can i loosen the glow plug a bit??so that easy to pull.thank you..
發表於 2009年6月22日 02:12 AM | 顯示全部樓層
HI !
當然可以放鬆火咀起動,你的燃料箱是高於油門嗎?
Can put loose fire certainly Ju start , your fuel case is to be higher than throttle ?
注意!主要供應油料的一個必須低於油門的平水線.
Notice !  that one that supplies oil mainly must be lower than the flat water line of throttle .
[ 本帖最後由 C.K.Y. 於 2009年6月22日 02:21 AM 編輯 ]
 樓主| 發表於 2009年6月22日 07:23 PM | 顯示全部樓層
i don have the fuel case,,i just have fuel tank.wat is the fuel case??what is the purpose of the fuel case.do u think i will have the light pull of my pull start,after breaking in my engine..my engine is GO brand..thank you very much.
chai87..
GMT+8, 2026年4月22日 02:17 AM
