樓主: 台南阿明
{台南86高架橋}下一群開心玩車的朋友
發表於 2010年9月8日 07:03 PM | 顯示全部樓層
Tamiya is proud to announce the release of the M-06 PRO Chassis. This RR (Rear Motor, Rear Wheel
Drive) chassis is a completely new design and features a bathtub chassis with a low center of gravity
and optimum balance. The M-06 PRO chassis has excellent rear end stability and overall controllability
and is a vast improvement over the previous generation M-04.
About the Model
-This is a 1/10 R/C assembly model kit.
-Three adjustable Wheelbase Lengths (210mm/225mm/239mm).
-The battery is longitudinally placed for optimum chassis balance.
-Comes fully loaded with over 13,000 yen's worth of Option Parts, such as:
Item 54179 M-05 Ball Bearing Set
Item 53642 5mm Alu. Ball Connector (Blue)
Item 42168 Touring Car Short Spring Set (Black)
Item 54000 Hi-Torque Servo Saver (Black)
Item 54121 Alu. Horn for Hi-Torque Servo Saver
Item 54195 M-05 Alu. Turnbuckle Steering Rod
Item 54193 M-05 Alu. Steering Post
Item 54192 M-05 Alu. Steering Link
Item 50746 CVA Super Mini Shock Unit Set (Clear)
Item 53539 5.5mm Alu. Spacer Set
Item 53456 TA04 Turnbuckle Upper Arm Set
Item 53159 4mm Anodized Flange Lock Nuts (Blue)
-The M-06 comes equipped with the same gear ratios as the M-05.
-8-spoke white wheels and 60D tires included.
TRF417
About the Item
-The chassis design is focused on weight distribution and high-traction characteristics, with *the new
maximum chassis weight rule in mind. *The 2012 world championship regulations state that the Max.
chassis weight will be restricted to 1,350g. (1,450g in 2010).
-The TRF417 has an optimized chassis layout for high-power lithium batteries and brushless motors.
-One-piece aluminum motor mount offers extra strength and durability to handle high-power motors,
enabling transmission of the motor power to the drivetrain with minimal friction loss.
-Compared to the TRF416, the motor position has been moved about 2.0mm towards the center to keep high
traction during racing.
-By using a 19T pulley, the secondary gear reduction becomes 1.94, which is very close to the ideal rate
for brushless motors (2.0). With this, the car has less flexing resistance on drive belts and speed loss is
minimized when the throttle is off.
-Newly designed steering linkage is not connected to the upper deck, providing improved flexibility to hold
traction during cornering.
-Newly designed ball diff housing and plates provide extra durability.
-Identical front and rear bulkheads.
-Comes equipped with short reversible suspension arms and TRF416 uprights.
Newly Designed Parts
Front/Rear Carbon Damper Stays
Front/Rear Aluminum Bulkheads
Aluminum Motor Mount
Aluminum Center Shaft
Aluminum Diff Joint
Aluminum Steering Arms and Linkage
Diff Plates
Wheel Axle
Cross Joints
19T Pulley
Carbon Lower & Upper Decks (thicknesses TBA)
 樓主| 發表於 2010年9月8日 07:52 PM | 顯示全部樓層
大ㄟ~! 你用這.....是要我難堪嗎??
417 我是看江董 發言 才知道的~!
發表於 2010年9月8日 08:05 PM | 顯示全部樓層
隨便看到其中一行
417發展重點在於車重的減少和高牽引的特性
(高牽引我看不太懂我猜他的意思是車性有好的尋跡性應該是比較好操控吧
或是對於輪胎有更好的磨擦力也就是抓地力)
跟416比馬達位置朝裡面移動2MM
車重從1450克減為1350克
小皮帶齒輪改為19T傳動率變為1.94
上面一堆料號那邊
M06 PRO裡面包含13000日元的改裝品
包含:
...ALU是鋁合金的意思
.....很多M05的改裝品
所以說買M06比M05划算摟(但我猜售價會提高吧)
還包含白輪框和60D熱熔胎
看了圖片ㄟㄟㄟㄟM06是後驅車ㄟ
還有寫說跟M05用同樣齒輪組
以上圖片轉載自http://doraf.blog92.fc2.com/blog-entry-322.html
2012年世界賽使用
那還要等很久ㄟ
.............2012不是世界末日嗎
用GOOGLE收尋了一下10/16~17全日本模型展好像有TRF417和M06 PRO會展出
納等看照片吧
[ 本帖最後由 Ystrong 於 2010年9月8日 08:35 PM 編輯 ]
發表於 2010年9月8日 08:47 PM | 顯示全部樓層
小赫
我能不能跟你借3M噴膠來試噴勒
感恩
發表於 2010年9月8日 08:49 PM | 顯示全部樓層
給大家參考~~
你可能沒聽過自排車會卡在半山腰動彈不得,原因可能就是排檔桿打不動---
車子停在路邊,無緣無故被前後車撞到移動,而導致變速箱損壞,原因就是沒拉手剎車......
或許以為是危言聳聽,其實沒有切身體會,很難了解其嚴重性,正確做好駐車要領是很重要的
自排箱的 駐車檔(P檔)是利用一爪形駐車鉤與棘輪裝置的咬合駐車鉤裝在變速箱本體,棘輪多半裝在最終傳動機構 .當停車打入P檔時,自排箱並不是靠引擎剎車,而是將傳動機構鎖住自排車 .在斜坡時停車,最好先拉手剎車,等車子幾乎不會移動時,再打入P檔,才不致於傳動軸因為車子本身的重量,使得棘輪與駐車鉤卡死,嚴重的話,排檔桿將無法移動。
自排車正確停車方法應該是:踩煞車 --> 排入 N 檔 --> 拉手煞車 --> 放掉腳煞車,確定車不會滑動--> 再排入P檔即可
可是一般人都是先排入 P 檔 --> 再拉手煞車 -->這是錯誤的方法
發表於 2010年9月8日 09:39 PM | 顯示全部樓層
阿泰這個真實用....
我爸以前的S320常常卡在P檔打不出來....
後來就燒了...10幾萬的樣子= ="
阿明...我不是為難你啦...因為我也看不懂
M06第一段就是說改成RR後置馬達+動力啦
[ 本帖最後由 HOHNA 於 2010年9月8日 09:45 PM 編輯 ]
GMT+8, 2026年5月28日 04:56 PM
