查看: 1357|回復: 0
【童愛模型】GW CORVUS 50CC V2碳纖版 B塗裝,特價14500元
發表於 2014年4月1日 07:07 PM | 顯示全部樓層 |閱讀模式
WING SPAN:89-1/4" (2265mm)
LENGTH:86-1/2" (2200mm)
WING AREA:1482sq in (95.6sq dm)
FLYING WEIGHT:16.5-17.8lbs (7500-8100g)
ENGINE:50-70cc gas DLE55、DLE61、DA50、DA60、GP61
Electric Power:Hacker Q80-8m with 12S 5000mah 24×10 prop
Or other 4000Watt electric motor
ESC:160A
RADIO:4+CH/5-6S
The new V2 version of Corvus Racer 540 50CC has the following Improvements from previon version:
1.Control services is larger than V1 version. Up to 50 degrees of throw on all control surfaces. Best for more vibrant aerobatic flight.
2.Improved wheels with more durable materials and filled with rubber.
3.Using high quality cap head screws.
4.Improved ball link assembly.
5.Improved new Axle the material of Axle is stainless steel.
6.Improved new Dual Fiberglass horn assembly.
7.Flat nylon hinges for better flying strength.
8.Include Side Force Generator's(SFG)
9.Larger carbon fiber wing tube diameter than V1 previon version.
10.This V2 new design with a longer fuselage moment arm aiding the tracking of the model,giving it rock sold precision flight.Making it perfect for modern day flight schedules for IMAC and Freestyle
連絡方式:0912-278833 蔡先生
上一篇:【童愛模型】GW CORVUS 50CC V2碳纖版 A塗裝,特價14500元
下一篇:【童愛模型】GW SBACH342 50CC V2 A塗裝,特價13200元
GMT+8, 2025年12月30日 01:28 PM
