查看: 1243|回復: 4
[完成] 全新 F86 導風扇, 原廠已組裝好, 含11個伺服..翼長110cm.
發表於 2012年11月4日 07:52 AM | 顯示全部樓層 |閱讀模式
全新 F86 導風扇, 原廠已組裝好, 翼長110cm.
原廠已組裝好含11個伺服, 轉向, 電變, 馬達, 僅需接收, 電池即可
簡單裝上機翼即可爽飛, 我的經驗是一小時內
售 4300 , 我買的國際運費 800 , 關稅 420 我自行吸收, 箱子很大, 希望面交
龍潭科學園區, 龍潭, 關西, 新竹寶山, 頭份等交流道都可以面交 (週一到週五).  週末頭份可面交
購自 Hobbyking , US$141.9 .
http://www.rctw.net/hobbyking/store/uh_viewItem.asp?idProduct=17341
請將網址 rctw點net 改 hobbyking點com
(請將瀏覽器語系改英文才能連)
堆太多模型了 (家裡放了 10 架飛機, 2 架直升機(已賣出2台, 但想買800E), 6 部大車, 1 艘1米船....,  誰家老婆不念的).  先意思意思賣掉全新的, 再慢慢 Balsa 更大的飛機
A true cold war warrior, the F-86 Sabre found fame in the 1950's Korean conflict, it is a genuine classic with good reason, and this superb EPO Plug N Fly model really does this amazing aircraft justice.
Being PNF it is a fast build, the powerful EDF unit/ESC combo is pre-installed as are all the servos. This model is a good size and needs a 4s Lipoly to achieve the kind of performance you are looking for, also for a nice change in this class, the Lipoly compartment has been designed to take a large pack for decent flight times.
As well as being a superb looking and performing model, this Sabre is packed with features such as pre-installed electric retracts, optional drop tanks, flaps are again pre-installed as are the airbrakes which you can either set up on a seperate channel or connect to extend with your flaps, in fact this tough EPO jet only needs one thing......a Mig 15 from this new range of cold war classics to dogfight with!
Specs:
Wingspan: 1103mm 翼長
Length: 1085mm  機身長
Flying Weight: 1500g  起飛重量
Wing Load: 100g dm2
EDF: 70mm with 2836kv 2770 Outrunner Brushless Motor  導風扇內含
ESC: 45A  電變內含
Servo: 9g x 11  , 11 顆伺服, 內含
6~7 Channel (throttle, elevator, aileron, rudder/steering, retracts, flaps/airbrake)
Includes:
All Hardware
Instruction Book
Glue
Requires:  僅需接收及電池
Your Own TX/RX minimum 6 Channel
3200mAh 4s Lipoly Battery
[ 本帖最後由 kenning 於 2012年11月8日 11:44 AM 編輯 ]
上一篇:[2900]全新 1/4 GoKart, 全車碳纖維底盤+ 全新內轉3900kv無刷馬達
下一篇:徵F9255伺股機
發表於 2012年11月4日 09:28 PM | 顯示全部樓層
很喜歡.........
 樓主| 發表於 2012年11月5日 01:32 PM | 顯示全部樓層
回復 1樓 kenning 的帖子
自推一下...............................................
光 11 個伺服 11x200 =$2200 , 電變,馬達,導風扇組........很划算的
發表於 2012年11月5日 03:59 PM | 顯示全部樓層
回復 1樓 kenning 的帖子
你好.請問可不可.台南.寄貨運..4300含運
 樓主| 發表於 2012年11月7日 06:30 AM | 顯示全部樓層
回復 4樓 小安子 的帖子
已 PM. 沒問題.
GMT+8, 2025年12月30日 09:13 PM
