查看: 2454|回復: 11
[陸/車] [2900]全新 1/4 GoKart, 全車碳纖維底盤+ 全新內轉3900kv無刷馬達
發表於 2012年11月4日 07:22 AM | 顯示全部樓層 |閱讀模式
本帖最後由 kenning 於 2013年11月13日 08:19 AM 編輯
全新 1/4 GoKart, 全車碳纖維底盤, 金屬轉向座, 質感極佳
+ 全新內轉 3900 kv 馬達. (都自 hobbyking 一次購買的)
(之前被車友晃點, 擱置一陣子, 重新開始拍賣. 謝謝)
GoKart + 全新 內轉3900kv無刷馬達 共 NT$2900 含運.
都是全新未拆未組裝
車子原廠已組裝好含轉向伺服, 僅需安裝人偶, 馬達, 電變
(國際運費我自行吸收了)
購自 Hobbyking , US$69.95.
http://www.rctw.net/hobbyking/store/__17898__TURNIGY_1_4_Scale_Brushless_GoKart_KIT_.html
零件 =>
http://www.rctw.net/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=412
請將網址 rctw點net 改 hobbyking點com
(請將瀏覽器語系改英文才能連)
零件從 Hobbyking 都很齊, 本人已習慣每月買一次了.
出售原因: 兒子喜歡貨卡較粗曠以及堆太多模型了 (家裡放了 10 架飛機, 2 架直升機(已賣出2台, 但想買800E), 6 部大車, 1 艘1米船....,  誰家老婆不念的)
The TURNIGY 1:4 scale gokart is a real blast to drive, with its low center of gravity and ultra sticky TruRubber* tyres which keep the kart turning sharply. A powerful full size servo is included with kart to keep the steering precise and quick, while the non differential rear tyres lay rubber on each corner!
The entire floor pan is made of 4mm Carbon fiber sheet with very little suspension travel at the rear giving the gokart very realistic handling.
搭配 35A 電變, 3900 內轉無刷馬達. 全部全新未安裝
可使用 2S ~ 3S
原廠建議You will need a 35A ESC 電變, an inrunner motor around 3900Kv馬達, a tansmitter and receiver and 2S LiPo battery.
Stickers are included, but the driver is unpainted so you can create your own race livery on the driver.
Spec.
車長 Length: 450mm
Width: (F)262mm / (R)305mm
Height: 201mm
Ground Clearance: 5~12mm
最高速度Top Speed: 45~60km/h,  搭配 3S 更快
Tyres: 56×30mm / 58×45mm
Pinion: 13T (Required)
Gear Ratio: 13:2.37
Drive/Main Ratio: 13:47
T-Tube/Main Ratio: 20:30
Driving Weight: 2,100g (approx.)
Required.
35A Car ESC (TR35A-V2, 60A-SL or HK-45A)
Receiver/Transmitter (HK-GT2 or other 2~3 channel Tx)
LiPo: 2S 4000~5200mAh Hardcase Lipo (140x48x50mm max size)
13T Pinion gear.
內轉無刷馬達 2848,. 3900kv, 2S~3S, 500W
[ 本帖最後由 kenning 於 2012年12月6日 12:47 AM 編輯 ]
上一篇:誠徵野獸跟rg611b.rg831
下一篇:全新 F86 導風扇, 原廠已組裝好, 含11個伺服..翼長110cm.
 樓主| 發表於 2012年11月5日 01:34 PM | 顯示全部樓層
GoKart + 全新 內轉3900kv無刷馬達 共 NT$2700 含運.
很划算的
發表於 2012年11月7日 03:19 AM | 顯示全部樓層
回復 2樓 kenning 的帖子
NT$2500 含運
 樓主| 發表於 2012年11月7日 06:41 AM | 顯示全部樓層
回復 3樓 ktv393 的帖子
OK. 沒問題. 已 PM 帳號. 謝謝您
發表於 2012年11月7日 10:27 PM | 顯示全部樓層
回復 4樓 kenning 的帖子
電變是多少A?
(TR35A-V2, 60A-SL or HK-45A)?
 樓主| 發表於 2012年11月8日 10:11 AM | 顯示全部樓層
回復 5樓 ktv393 的帖子
TR35A-V2 : 24.99
, 60A-SL : 39.99
HK-45A : 19.99
建議 45A 即可. 有時會認為說以後可以挪作他用, 買高一點等級的. 我以前也是這樣想, 不過想法會一直變, 下一台車不一定適用你現在或現在買高一級的電變.  且東西會越好越便宜.
我當時是選 HK-45A , 但是全部都缺貨. =>
Standard 45A car esc with forward reverse and a good range of features such as timing adjust and breaking. Supports a wide range of motors. Very reliable!
Features:
Full protection feature including low voltage, over-heat, throttle signal lost, startup
protection and self-check.
Compatible with sensorless brushless motor.
Excellent startup performance, linear and quick throttle response.
Supports highest motor speed 240,000RPM(2 poles), 80,000RPM(6 poles) and 40,000(12 poles).
Easy to configure with program card.
System can automatically detect throttle neutral point, and neutral range is adjustable.
Three work modes for different environments.
4 step reverse force adjustment
5 step start force adjustment.
3 step brake force adjustment
5 step drag brake force adjustment,
4 step initial brake force adjustment.
Specification:
Input voltage: 2-3S Lithium batteries / 4~12 Ni-xx
Cont. Current: 45A
BEC output: 2A/5V (Switch)
Size( length X width X high): 45x32x20mm
Weight: 60g
GMT+8, 2026年1月12日 03:36 AM
