查看: 1066|回復: 0
GWS S03N-II HP and GWS S03N-II D HP2BB
發表於 2011年1月21日 05:30 PM | 顯示全部樓層 |閱讀模式
GWS new servos S03N-II HP and GWS S03N-II D HP2BB will be avalible soon.
這是規格超越日本 F 牌暢銷世界的 S9252 (售價為 NT$2000+ ) 規格的GWS產品! GWS S03N2價格卻只需要 NT$300~510.
由廣營電子在中國研發製造的舵機瞬時性能超越日本韓國與德國的水平!  很高興在此與您分享我們的成果!
我們不斷的刷新紀錄 創造世界性的新指標與規格.
GWS S03N-II HP MSRP$10.00 for 4.8~6.0v ( 台灣售價 NT$300 )
4.8v 8kg 0.148sec.. 6.0v 9kg 0.130sec.
GWS S03N-II D HP2BB MSRP$17.00 4.8~6.0~7.4~8.4v ( 台灣售價 NT$510 )
4.8v 8.2kg 0.134sec.. 6.0v 9kg 0.114sec.
7.4v 10.5kg 0.102sec.. 8.4v 11.4kg 0.095sec.
As usual, GWS always more gear ratios for your choice of application to get the best optimization!
GWS new servos S03N-IIF HP and GWS S03N-IIF D HP2BB will be avalible soon. Yet, there another speedy choice GWS S03N-IIXF HP and GWS S03N-IIXF D HP2BB. ( F=Fast, XF=Xtra Fast D=Digital ).
GWS S03N-IIF HP MSRP$10.00 for 4.8~6.0v
4.8v 7.0kg 0.131sec.. 6.0v 8.0kg 0.123sec.
GWS S03N-IIF D HP2BB MSRP$17.00 4.8~6.0~7.4~8.4v
4.8v 7.0kg 0.110sec.. 6.0v 8.1kg 0.098sec.
7.4v 9.1kg 0.081sec.. 8.4v 9.8kg 0.074sec.
GWS S03N-IIXF HP MSRP$10.00 for 4.8~6.0v
4.8v 6.0kg 0.099sec.. 6.0v 6.8kg 0.086sec.
GWS S03N-IIXF D HP2BB MSRP$17.00 4.8~6.0~7.4~8.4v
4.8v 6.0kg 0.089sec.. 6.0v 7.0kg 0.078sec.
7.4v 8.0kg 0.070sec.. 8.4v 8.5kg 0.064sec.
All of those servos weight only 33g.
You may easily compared with a F brand most popular S9252 servo specs as below: Price:$84.99
But GWS analog only $10.00, Digital type only $17.00. While both versions performance result better than S9252.
Control System: +Pulse Width Control 1520usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8 Volts Only
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.14sec/60 degrees at no load
Stall Torque (4.8V): 92 oz/in. (5.5kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Counter Clockwise/Pulse Traveling 1520-1900usec
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: All Nylon Gears
Connector Wire Length: 12"
Dimensions: 1.6" x 0.8"x 1.5" (41 x 20 x 38mm)
Weight: 1.8oz. (50g)
Who give more torque? Who run faster? Yet, GWS S03N2 is way much lighter!
Just measured and got 33g ( 1.16oz ) only! By far better than S9252's 50g weight.
上一篇:請教變壓器或電源供應器有幾A之別,請問有何差異?
下一篇:2.4GHz的發射天線該如何擺放?
GMT+8, 2025年12月31日 03:10 AM
