樓主: ffx80314
【求助】小弟跪求! GRA60A電子變速中文設定
 樓主| 發表於 2005年10月26日 01:02 PM | 顯示全部樓層
Programming the speed controller to your transmitter stick and activating/deactivating the brake:
Attention: The soft start time will change with your servo travel. If you choose the servo travel 100% the soft start time is slow. If you choose a smaller servo travel (f. e. 50%) the soft start time is faster. Choose the servo travel, as you like the soft start time most.
Programming the speed controller with the SET-button:
1. switch on the transmitter, move the transmitter stick to the position "neutral" (motor off)
2. connect the battery to the speed controller and switch on the speed controller
3. you will hear two beeps.
4. push the SET-button
5. you will hear one beep.
6. hold the transmitter stick in the position "neutral" (motor off), until you hear two beeps (after approx.2 sec.)
7. a) If you don't want to have the brake, move the transmitter stick within the next 3 sec to the position "full throttle" and hold
       the stick in this position until you hear three beeps.
    b) If you need the brake, move the transmitter stick within the next 3 sec to the position "full throttle" and immediately next to the position "full brake" and hold the stick at the position "full brake" until you hear three beeps.
8.) The speed controller will be activated, as soon as your transmitter stick is in position "neutral" or "brake" and your speed controller did beep three times.
 樓主| 發表於 2005年10月26日 01:04 PM | 顯示全部樓層
Originally posted by rex at 2005年10月26日 12:44 PM:
這顆除了煞車應該沒有特別需要設定的....我裝了就直接開出企了....
就是不知道該怎設定!  剛開始要如何設定呢?
例如說電池插入之前搖桿要放在中間還是上面那些的...
當初不知道插入電池後前進沒反應~後退一下!  然後就冒煙哩!!!
請教大哥您是如何啟動呢?
維修了$800元!!!!!
 樓主| 發表於 2005年10月26日 01:07 PM | 顯示全部樓層
補充!  翻譯軟體顯示的有一些句子不順!  所以不太董呢!
rex大哥...您設定煞車是不是有要按電變後面的按鈕!
我看翻譯軟體好像有提到要按ㄝ!
發表於 2005年10月26日 02:13 PM | 顯示全部樓層
請教大哥您是如何啟動呢?
維修了 ...
請問是否有將遙控器所有的設定歸零或另選一組新的設定,正逆轉開關是否有設立錯誤,一般就算設定反也不會冒煙,除非正負電源接反,但如果已經冒煙,可能MOS-FET已經燒毀了,我之前就是用槍型遙控器,因功能太多把中立點調走位,導致電變無法感應到正確位置,所以你可以先試試看?
 樓主| 發表於 2005年10月26日 02:27 PM | 顯示全部樓層
我也不清楚ㄝ!  目前等各位大大幫助中才敢再次設定!  不過電池沒接反就是了!!!!!
謝謝您~~我會注意看是否正逆轉之類ㄉ!
發表於 2005年10月27日 10:47 AM | 顯示全部樓層
打開發射机 將搖桿置於中央位置
將电源和变速器連接 打開变速器电源
会聽到 嗶嗶 二聲
按下設定鈕(set button)
你會聽到一個嗶聲
保持搖桿在先前的中間位置(馬達沒有転動的狀態) 大的二秒鐘左右 直到聽到嗶嗶 二聲
7. a) If you don't want to have the brake, move the transmitter stick within the next 3 sec to the position "full throttle" and hold the stick in this position until you hear three beeps.
     如果不要煞車 在三秒鐘內將摇桿推到全速位置 保持位置直到聽到嗶嗶嗶三聲
如果要煞車 在三秒鐘內將摇桿推到全速位置 然後立刻直接反向撥到煞車位置 保持位置直到聽到嗶嗶嗶三聲
GMT+8, 2026年4月26日 05:41 PM
