查看: 1473745|回復: 22
【求助】小弟跪求! GRA60A電子變速中文設定
發表於 2005年10月26日 10:32 AM | 顯示全部樓層 |閱讀模式
小弟之前送修的Graupner 60A電子變速回來了!
不過依然不知道該如何設定! 當初他回老家就是因為設定錯誤之類的!  直接冒煙!!
是否有大大知道該電變如何跟遙控器上面做設定呢?  不要又回老家了
謝謝大大!
上一篇:【討論】如何選出適合使用的無刷?
下一篇:【討論】請問無刷馬達?
發表於 2005年10月26日 10:55 AM | 顯示全部樓層
大頭 你要不要將說明書po上來讓大家給您瞧瞧
發表於 2005年10月26日 11:05 AM | 顯示全部樓層
Alex大哥說的沒錯!
若您無法將原文一字字的key上來...
您也可以將說明書掃瞄成圖檔後再po上來!
這顆電變是Graupner的最新款...
市面上擁有它的人應該不多!
要求中文說明書很難...
不如po上來讓大家一起集思廣益想辦法解決!
 樓主| 發表於 2005年10月26日 12:13 PM | 顯示全部樓層
好吧!  我來po看看ㄅㄟ....
Safety overheating cut-off(not Pico8):
If the speed controller's output stage threatens to overheat, a safety temperature cut-off switches off the motor function until it has cooled down to a safe level. After cooling down, you can activate the motor function again. To do this, you have to move the transmitter stick to "motor off position".
Under voltage cut-off:
If the battery reaches the under voltage cut-off, the speed controller will switch-off the motor. If the battery voltage gets high enough again, you can activate the motor function. To do this, you have to move the transmitter stick to "motor off position". If you use the speed controller with the BEC-System, make sure to land your model as soon as possible, before the battery voltage is too low for a safe receiver operation.
How to switch on and activate the speed controller (The speed controller does only beep with connected motor):
1. switch on the transmitter
2. connect the battery and switch on the speed controller
3. the speed controller will beep two times.
4. If your transmitter stick is at the position "neutral" or "brake", the speed controller will beep three times and is now active.
5. If the speed controller fails to detect the brake range, it is likely that you need to reverse the throttle channel; alternatively you may have reduced the throttle servo travel to less than 100%. If you don't like the factory setting of the speed controller, you should follow the next programming steps.
發表於 2005年10月26日 12:39 PM | 顯示全部樓層
請問您維修連同運費大概要花多少銀兩?我也要把GRA POWER MOS 60A送修看看...
發表於 2005年10月26日 12:44 PM | 顯示全部樓層
這顆除了煞車應該沒有特別需要設定的....我裝了就直接開出企了....
GMT+8, 2025年11月14日 10:56 AM
