查看: 432538|回復: 4
【問題】請問各位先進: FUTABA SERVO 的問題
發表於 2003年3月31日 09:03 PM | 顯示全部樓層 |閱讀模式
FUTABA的SERVO有的特別標示Ni-cd 4.8V專用, 例如:S9250, S9204,
請教各位先進, 是否可用Ni-MH 6V Batteries.
上一篇:【分享】菜鳥遙控飛行網......重新出發
下一篇:【求助】YS63 Idle 轉速變動與油管氣泡問題
發表於 2003年3月31日 09:28 PM | 顯示全部樓層
6V可
建議不要 因現在的SERVO 已很快很有力了
 樓主| 發表於 2003年4月1日 12:19 AM | 顯示全部樓層
First of all, Thanks for your reply, RC.
Secondly, 用6.0V Battery 的理由是因為想要Rudder Servo (S9450)的速度;
我的System: Two S9204 for Aileron
                     Two S9250 for Elevator
                     One S9450 for Rudder & S135 for Throttle
So, Digital Servo and Csr Servo 的混用是否會有問題?
Thank you very much, again.
Samu
發表於 2003年4月17日 09:34 PM | 顯示全部樓層
Futaba servo 9204
前些日子買了一顆9204,但一直拿不定主意該用4.8v or 6v
經詢問美國Fataba及日本Futaba總社,都建議用4.8v.原文如下,供各位參考
Dear Mr. Chang
Thank you for asking via Futaba web site.
S9204 is specially designed for high-torque, therefore very high current
drain is normal at startup.
If using dry-cells, there will be less performance and when using systems
with the battery fail-safe function, the operation time will be very short.
Please use it with a NICAD battery.
If using S9204 at 6.0V, the life of the servo is decreased extremely.
Please use it at 4.8V.
Best regards,
R/C division
Futaba Corporation
Dear Sir:
Thank you for your Email.
The Futaba S9204 servo, which is now discontinued was originally designed to be used with standard 4.8 V NiCd battery packs.  When it came out, 6V operation was not very common, so Futaba did not test it with 5-cell NiCd battery packs.  We don't know how it will hold up if you use such a pack.
Also, 5-cell NiCd battery packs can be as high as 7.5 V when fully-charged, with the voltage gradually dropping to 5.5 V, when the pack is depleted.  The higher voltages can cause damage to servos.
In short, we don't know how your  S9204 servo will fare with a 5-cell battery pack for power.  It's not been tested that way.
We hope you find this information helpful.  Should you have any further questions or concerns, please do not hesitate to contact us at this email address.  (Please be sure to copy all previous emails into any future questions.)
DID YOU KNOW that our web pages now all contain FAQs? (Frequently asked questions)  Please drop by and take a look! We hope you'll find the information helpful and valuable to you.
Sincerely,
Futaba Service Center USA
3002 N. Apollo Dr.  Suite 1
Champaign   IL   61822
USA
發表於 2003年4月19日 01:05 AM | 顯示全部樓層
以下引用由 KC 在 2003年04月17日 下午 05:日 所發表的內容:
Futaba servo 9204
Dear Mr. Chang
Thank you for asking via Futaba web site ...
最主要的是  鎳鉻電池 對SERVO  PROWER  有很好的幫助   (電流比較大)
想一想為甚麼原廠均賣   鎳鉻電池--------------------
GMT+8, 2025年10月31日 06:57 PM
