查看: 4241|回復: 40
[一元起標] 一元起標 美國3dhs 60" YAK55,4月19日結標
發表於 2015年4月15日 07:44 PM | 顯示全部樓層 |閱讀模式
本帖最後由 cute969211 於 2015年4月15日 07:46 PM 編輯
美國3dhs的飛機,是設計給世界級的TOC 3D比賽用機,性能上沒話講,好康只丟一次
全新巴爾沙木飛機4月19日晚上10點結標,售價9860元,一元起標,標多少賣多少,只有一台
運費150元
60"Yak 55M
The 3DHobbyShop 60" Yak 55 is super-high performance scale wood/carbon ARF aircraft.  Using the recommended Torque 6S power system, the Yak 55 is very fast and powerful, and capable of a staggering array of hardcore 3D, precision, and gyroscopic maneuvers.  Available in two gorgeous color schemes in genuine Oracover/Ultracote, the Yak includes all of the features you've come to expect in 3DHS aircraft:
  • Carbon wing tube
  • Carbon landing gear
  • Aluminum axles
  • Carbon tail gear
  • Ball link hardware
  • Carbon fuselage stringers
  • Composite control horns
  • Wing bags
  • Vinyl graphics
Compatible with a variety of power systems using 4S-6S Lipo batteries, the Yak requires 4 mid-size metal gear servos.  Hitec HS-7245MG's are recommended.
Like our 91" Yak 55 model, the 60" Yak 55 includes a modular wing-tip system for variable yaw-stability.  You can fly with or without the included SFG's, and when using the SFG's you can fly with or without the differential-drag wingtip blocks.  This tip arrangement allows you to tailor the feel of the Yak in high-speed maneuvers to your liking.
If you want the next level of insane aerobatic performance in a mid-size lightweight electric package, the Yak-55 is here for you.
組裝說明書
Specifications:
Wingspan: 60"
Length: 56.25" with spinner
Wing Area: 620 Sq. Inches
Weight: 4.5-5.5 lbs.
Required Equipment:
Motor:
Hacker A40-10S with 4S mAh, 14x7 prop
Hacker A40-12S with 5S mAh, 13x6.5 propHacker A40-12S with 4S mAh, 14x7 prop
Hacker A40-14S with 5S mAh, 14x7 prop
Torque 4016T/500 MKII with 6S mAh, 16x7 prop
ESC:
Castle Edge Lite 75A
AirBoss 80
Hacker X70 SBEC
Castle Ice Lite 75A
Prop:
14 x 7
15 x 7
16 x 7
Spinner:
63mm (2.5 inches)
Servos:
4 x Hitec HS-225MG (Good)
4 x Hitec HS-5245MG (Better)4 x Hitec HS-7245MH (Best)
Servo Extensions:
1 x 18" Elevator
2 x 6-8" Ailerons
1 x 12" ESC
上一篇:售[取消]Castle 4600kv RPM MAX 100000
下一篇:清一些 飛機。引擎。
發表於 2015年4月15日 07:53 PM | 顯示全部樓層
500開始
發表於 2015年4月15日 08:10 PM | 顯示全部樓層
600
發表於 2015年4月15日 08:16 PM | 顯示全部樓層
700
發表於 2015年4月15日 08:20 PM | 顯示全部樓層
750
發表於 2015年4月15日 08:28 PM | 顯示全部樓層
1000
GMT+8, 2025年12月5日 01:31 AM
