查看: 2034|回復: 3
FAA 可望在近期定出UAV規範
發表於 2013年12月9日 10:27 PM | 顯示全部樓層 |閱讀模式
本帖最後由 stishsun 於 2013年12月9日 10:33 PM 編輯
FAA 可望在近期定出UAV規範
簡單的說無人飛行器可以飛到1200ft,在靠近機場附近只能飛700ft
以空域來看,就是這種無人機可以在Class G空域飛行
另外就是不能做商業行為,文中提到有個人收錢在大學裡做空拍被FAA罰了1萬美金...
如果台灣比照美國規範,不能做商業行為,那一堆航拍公司等著關門
So you want to fly drones? Here’s what the law says
SUMMARY:
Where can you fly a drone? As long as you’re not doing it for business purposes, there are very few rules. Here’s a map and a quick explanation of where your drone can go.
Amazon may have big plans to fill the urban air with drones, but many amateurs have already beaten the company to the punch. This month, my colleague Signe Brewster showed off some beautiful footage of her DJI Phantom 2 Vision quadcopter’s flight around San Francisco, and hundreds of other Americans are using drones for photography, farming or just plain fan.
Want to fly a drone without falling afoul of the law? The good news is that while the FAA will soon have new rules on unmanned aircraft, there are now few restrictions for amateur flying fans. Here’s a very unofficial guide, and some graphics, that reflect the current state of the law.
Class G is a go
Airspace is sliced up into different regulatory layers from the ground unto outer space. The Federal Aviation Administration pays a lot attention to Class A — all U.S. airspace from 18,000 to 60,000 feet — where commercial planes fly. Then are the airspaces around airports, called Class B (big airports), C and D (smaller cities), that look like inverted wedding cakes and stretch up from the ground.
Drone fans, pay attention to Class G: an unregulated space from the ground to 700 or 1,200 feet, where the drones can fly below the airport tiers. Here’s an FAA image(I’ve added the arrows):
The 700 to 1,200 feet rule is distance from the ground, not sea level — so if you’re in Denver or another high altitude city, you can fly higher. Here’s a partial view of how a Popular Mechanics explainer chose to show the airspace:
While the FAA suggested in 1981 that model aircraft operators fly below 400 feet, the document was just an advisory, and two aviation lawyers contacted by Gigaom said the agency has no authority below 700 feet — for now.
“The FAA is already looking at it .. but it’s not going to happen for two years,” saidJohn Todd of Todd & Levi in New York, who noted that the number of amateur drones in the sky is growing quickly.
Here for pleasure, not business
When Amazon announced this month that it’s planning to deliver packages by drone, news outlets pointed out that the plan would have to get FAA approval, even though the drones would be flying at a low level. The reason is because Amazon wants to use the drones for a commercial purposes — an important distinction that, in the view of the FAA, gives it special regulatory authority.
But even this point is under debate. As Wired reported, the first lawsuit pitting the FAA against a civilian drone operator is underway in Virginia, where a photographer got in trouble with the agency for flying a drone over the campus of a university that had paid for his services.
The FAA fined him $10,000 for operating an aircraft in a reckless manner, but the photographer is challenging the ruling on technical grounds; saying the FAA didn’t conduct proper hearings, and that the agency’s regulations over commercial drones are invalid. The outcome of the case has implications not just for commercial photographers, but for a thriving drone industry related to farming, surveillance and other activities.
Finally, while your drone hobby may be beyond the reach of the FAA, there are still city and state laws about invasion of privacy, disturbing the peace and so on. This means that using your drone to snoop on people’s bedrooms or to terrorize the local hot dog vendor is probably a bad idea. Otherwise, drone aficionados appear free to enjoy what is still a largely unregulated activity.
有高手能幫我分析炸機原因嗎?
skylark osd 的usb線無法跟win8連線
發表於 2013年12月9日 11:45 PM | 顯示全部樓層
FAA 罰那空拍社攝影師是因為他的魯莽行為可能導至危害到他人安全.
如果真的要商業用途,定期做飛行器安撿與人員訓練考核是必要的
就如同我們開車需有駕照, 車子要定期驗車一樣
在商業運轉前有必要制定UAS法令來確保公眾安全
 樓主| 發表於 2013年12月10日 07:08 AM | 顯示全部樓層
文中沒說明這個攝影師怎麼個魯莽所以被罰,只說他收了錢,不過目前在美國任何UAV商業行為都是違法的,未來FAA似乎也沒打算開放
發表於 2013年12月15日 05:50 PM | 顯示全部樓層
冒昧請問一下,FAA裡的UAV定意是指什麼呢?
就是重量25 pounds以上的飛行器嗎?  還是只要是Radio Control就算是?
總覺用法律規範與自律使用是不同的事。
不過文中似乎不是正式的報導消息,詳細的還要進一步考證。
GMT+8, 2026年2月17日 09:51 AM
