查看: 2160|回復: 2
新款大力士 超級BEC
發表於 2013年6月18日 11:20 AM | 顯示全部樓層 |閱讀模式
新款大力士 超級BEC
This new Hercules Super BEC G2 continues after the legacy of the original Hercules Super BEC but now the G2 version has outstanding high current loads of 15 Amps continuous / 20 Amps peak. The Hercules Super Battery Eliminator Circuit G2 is a glitch free high efficiency, high power switching voltage regulator designed to work with all popular brands of R/C receivers and servos. It provides safe and consistent power to your R/C receiver and servo(s) that eliminates the need for a separate battery source. The Hercules Super will boost performance on your R/C model by reducing the overall weight while maintaining a high current output from high voltage sources up to a 14s LiPo battery (60V). The Hercules Super BEC G2 now has a built in power bus system that allows multiple servos to be plugged directly into the Hercules unit, this will eliminate any unnecessary voltage drops that can occur within the cabling that come with standard receiver connections that share the one power connection with multiple servos.
上一篇:KONTRONIK PYRO 750-56L電機
下一篇:600SX 和 550SX 頭罩有現貨
發表於 2013年8月6日 04:29 AM | 顯示全部樓層
請問大大這顆要價多少錢?要跟誰買貨呢
 樓主| 發表於 2013年8月7日 11:09 AM | 顯示全部樓層
GMT+8, 2026年1月7日 06:39 AM
