本帖最後由 seafisherman 於 2013年3月11日 09:33 AM 編輯
這一篇本來是貼在 EJ 大 Devo 10 那一串大樓
由於那一棟大樓 ,已成超級摩天高樓 ,
怕查詢不易 , 決定獨立出來 , 讓有興趣的大大方便查詢
如果大大們 , 有興趣玩玩
用 Devo 10 刷 Suv 大的韌體 + DSM2 接收器 [ 比如 小橘子接收 或 AR 系列 ]
+ 3G陀螺 ( 無平衡翼 ) , 玩一些 450 FBL 無副翼 的機子
在這貼上 PB 大網站的一些資料 , FBL 和 DSM2 的相關的協議的設定
以及 , 國外大大的 ini 範例 2 則
A. 範例 1 TREX 450FBL devo ini
B. 範例 2 Trex450 Pro Fbl XYZ devo ini
PS. 1.資料來源 Deviation 網站
2. 範例僅供參考 , 不代表直接套用就能使用 ,請自行刪增調整部分參數 ,
務必先在地面作完整測試 , 再進行實機測試飛行 ...
========分隔線==========
FBL 相關通道關係
For Devo protocol on FBL controller:
ch1 Elevator stick position
ch2 Aileron stick position
ch3 Throttle stick position
ch4 Rudder stick position
ch5 -not used-
ch6 Collective Pitch (we'll call it stick position for now, more on that in a second)
ch7 Gyro setting
DSM2 協議
For DSM2/X protocol, the FBL will expect the same information from your tx, just in a different order.
ch1 Throttle stick position
ch3 Elevator stick position
ch5 Gyro setting (this channel is often called the Gear channel on the Rx)
======分隔線 =============
範例 1 TREX 450FBLdevo ini
A special Thank you goes to Tom Z, because without his guides I would have given up. These are for:
Trex 450 Pro FBL with Beastx/Hobbymate sytem, not sure about Tarot/CopterX but should be close. One file is for a 2801RX and the other for Devo's.
All sticks and movement are set for 100%. Gyro is set at 70 and -50. Expo/Dr at 100/Line. Throttle Hold on Rudd DR Switch, set to full movement for auto-rotation.
Remember to remove the name after model# and if anyone see's anything wrong.....please let me know.
***Adjust the scalar for Channel 7. Its off, I set it up with Old 2801 Numbers causing tail wag. New files have better numbers, but will still have to be adjusted for your Heli.
name=TREX 450FBL
[radio]
protocol=DEVO
num_channels=8
tx_power=100mW
[channel1]
template=cyclic2
[channel2]
reverse=1
template=cyclic1
[channel3]
template=complex
[mixer]
src=THR
dest=Ch3
switch=FMODE0
curvetype=7point
points=-100,-66,-33,0,33,66,100
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=7point
points=95,90,85,80,85,90,95
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=7point
points=100,100,100,100,100,100,100
[mixer]
src=THR
dest=Ch3
switch=RUD DR
scalar=-100
curvetype=fixed
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel6]
template=cyclic3
[channel7]
template=expo_dr
[mixer]
src=GEAR
dest=Ch7
scalar=30
usetrim=0
curvetype=fixed
[mixer]
src=GEAR
dest=Ch7
switch=GEAR
scalar=-50
usetrim=0
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
[mixer]
src=AIL
dest=Virt1
switch=AIL DR
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
[mixer]
src=ELE
dest=Virt2
switch=ELE DR
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
switch=FMODE0
curvetype=7point
points=-30,-20,-10,0,33,66,100
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=7point
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=7point
[mixer]
src=THR
dest=Virt3
switch=RUD DR
usetrim=0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=240
[safety]
Auto=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch3
box2=Ch6
box3=Timer1
box4=Timer2
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=AIL DR
toggle3=RUD DR
tglico3=2
toggle4=GEAR
tglico4=4
quickpage1=Telemetry monitor
========= 分隔線 =============
Trex 450 Pro Fbl Tarot XYZ
name=Tarot 450fbl
[radio]
protocol=DSM2
num_channels=6
tx_power=100mW
[channel1]
safetysw=RUD DR
safetyval=-100
max=100
min=-100
template=expo_dr
[mixer]
src=THR
dest=Ch1
curvetype=5point
points=-100,-40,-40,-40,-40
[mixer]
src=THR
dest=Ch1
switch=FMODE1
scalar=40
curvetype=fixed
[mixer]
src=THR
dest=Ch1
switch=FMODE2
curvetype=fixed
[channel2]
reverse=1
template=expo_dr
[mixer]
src=AIL
dest=Ch2
scalar=60
curvetype=expo
points=40,40
[mixer]
src=AIL
dest=Ch2
switch=FMODE1
scalar=80
curvetype=expo
points=30,30
[mixer]
src=AIL
dest=Ch2
switch=FMODE2
curvetype=expo
points=20,20
[channel3]
reverse=1
template=expo_dr
[mixer]
src=ELE
dest=Ch3
scalar=60
curvetype=expo
points=40,40
[mixer]
src=ELE
dest=Ch3
switch=FMODE1
scalar=80
curvetype=expo
points=30,30
[mixer]
src=ELE
dest=Ch3
switch=FMODE2
curvetype=expo
points=20,20
[channel4]
reverse=1
scalar=40
template=expo_dr
[mixer]
src=RUD
dest=Ch4
scalar=60
curvetype=expo
points=40,40
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
scalar=80
curvetype=expo
points=30,30
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
curvetype=expo
points=20,20
[channel5]
safetysw=RUD DR
safetyval=-30
template=expo_dr
[mixer]
src=Ch5
dest=Ch5
scalar=30
usetrim=0
curvetype=fixed
[mixer]
src=Ch5
dest=Ch5
switch=FMODE1
scalar=25
usetrim=0
curvetype=fixed
[mixer]
src=Ch5
dest=Ch5
switch=FMODE2
scalar=25
usetrim=0
curvetype=fixed
[channel6]
template=complex
[mixer]
src=THR
dest=Ch6
switch=FMODE0
usetrim=0
curvetype=5point
points=-40,15,48,65,75
[mixer]
src=THR
dest=Ch6
switch=FMODE1
usetrim=0
curvetype=5point
points=-70,-16,25,60,90
[mixer]
src=THR
dest=Ch6
switch=FMODE2
usetrim=0
curvetype=3point
points=-100,-5,90
[mixer]
src=THR
dest=Ch6
switch=RUD DR
usetrim=0
curvetype=3point
points=-100,0,100
[channel8]
max=100
min=-100
template=simple
[mixer]
src=Ch8
dest=Ch8
usetrim=0
curvetype=5point
points=-97,71,0,-52,95
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=None
neg=None
step=0
[trim3]
src=LEFT_H
pos=None
neg=None
step=0
[trim4]
src=RIGHT_H
pos=None
neg=None
step=0
[trim5]
src=Ch5
pos=TRIM_L+
neg=TRIM_L-
value=-100
[trim6]
src=Ch6
pos=TRIM_R+
neg=TRIM_R-
[timer1]
type=countdown
src=THR
time=300
[timer2]
src=THR
[safety]
Auto=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch1
box2=Timer1
box3=Timer2
box4=Ch6
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch5
toggle1=FMODE0
tglico1=1
toggle2=FMODE1
toggle3=FMODE2
tglico3=2
toggle4=RUD DR
tglico4=4
▼ 下一篇:將super舵機齒換到mincp舵機的方法?請問大家充電的方式??▲ 上一篇:
