查看: 1485|回復: 8
[完成] Model motors AXI 4130/16 GOLD LINE 無刷馬達[★已完成交易★]
發表於 2012年12月13日 05:14 AM | 顯示全部樓層 |閱讀模式
AXI系列無刷馬達是由歐洲知名大廠Model Motors所設計生產,當眾多德系知名品牌為了降低成本紛紛改至中國大陸OEM生產(如某牌A系列)時,Model Motors仍然堅持以最高等級的材料精密的組裝在歐洲當地生產,其獨特的設計及優異的品質使其能再各種應用上都有相當突出的表現,也是眾多歐美玩家一致推崇及肯定的頂極無刷馬達。Model Motors全系列馬達皆採用耐高溫強力釹磁鐵,超高扭力的設計及多樣化的用途絕對是要求高水準表現的您最佳的選擇。
狀況很好,磁性超強,運轉超順無聲
簡介如下:
These brushless motors with neodymium magnets and a rotating case are manufactured using the latest technology from the finest quality materials. The hardened steel shaft supported by three ball bearings, and overall robust yet lightweight construction, ensure a long service life. A new feature in the AXI design is a provision for radial mounting (see picture). The optional radial mount set includes: mounting flange, propeller adaptor, securing collar, and screws. The unique design of these motors gives extremely high torque levels to turn large diameter and high pitch propellers with a high level of efficiency. This motor is suitable for large sailplanes weighing up to 6000g and sports aerobatic models up to 4500g.
Specification
No. of cells16 - 24
5 - 8 Li-Poly
RPM/V385 RMP/V
Max. efficiency88%
Max. efficiency current18 - 40 A (>84%)
No load current / 10 V1,3 A
Current capacity60 A/60 s
Internal Resistance63 mohm
Dimensions (diameter. x lenght)49,8x65,5 mm
Shaft diameter6 mm
Weight with cables409 g
Recommended setups for AXI 4130/16 GOLD LINE
55001946s1860A/60s77A16"x8"[/td]
40001416s1860A/60s77A16"x10"[/td]
45001598s1860A/60s77A14"x8"[/td]
65002296s1860A/60s77A17"x9"[/td]
8 - 10 ccm / .54-.60 -2stroke .70-.80 -4stroke
[ 本帖最後由 晨曦 於 2013年1月4日 02:18 AM 編輯 ]
上一篇:代友徵NOKIA 2730C 手機
下一篇:T-REX 450 Plus 賠錢賣只有一台9200元
發表於 2012年12月13日 05:25 AM | 顯示全部樓層
回復 1樓 晨曦 的帖子
簡介如下:
These brushless motors with neodymium magnets and a rotating case are manufactured using the latest technology from the finest quality materials. The hardened steel shaft supported by three ball bearings, and overall robust yet lightweight construction, ensure a long service life. A new feature in the AXI design is a provision for radial mounting (see picture). The optional radial mount set includes: mounting flange, propeller adaptor, securing collar, and screws. The unique design of these motors gives extremely high torque levels to turn large diameter and high pitch propellers with a high level of efficiency. This motor is suitable for large sailplanes weighing up to 6000g and sports aerobatic models up to 4500g.Specification
No. of cells        16 - 24
5 - 8 Li-Poly
RPM/V        385 RMP/V
Max. efficiency        88%
Max. efficiency current        18 - 40 A (>84%)
No load current / 10 V        1,3 A
Current capacity        60 A/60 s
Internal Resistance        63 mohm
Dimensions (diameter. x lenght)        49,8x65,5 mm
Shaft diameter        6 mm
Weight with cables        409 g
        5500        194        6s        18        60A/60s        77A        16"x8"[/td]
        4000        141        6s        18        60A/60s        77A        16"x10"[/td]
        4500        159        8s        18        60A/60s        77A        14"x8"[/td]
        6500        229        6s        18        60A/60s        77A        17"x9"[/td]
 樓主| 發表於 2012年12月13日 03:52 PM | 顯示全部樓層
哇!感謝帮忙說明。
 樓主| 發表於 2012年12月15日 12:36 AM | 顯示全部樓層
推....................................................................
 樓主| 發表於 2012年12月17日 12:50 AM | 顯示全部樓層
 樓主| 發表於 2012年12月18日 02:49 PM | 顯示全部樓層
GMT+8, 2025年12月24日 11:30 PM
