樓主: 技嘉
RealFlight G6.5
發表於 2013年1月27日 11:36 PM | 顯示全部樓層
版上是否有哪位大大願意借我G6的安裝程式讓我試裝看看。
 樓主| 發表於 2013年2月16日 12:45 PM | 顯示全部樓層
New RF6 public beta (6.50.016) is available
Version 6.50.016 is now available as a free public beta download. It includes new content and a minor editor fix.
The incredibly popular Heli-Max 1SQ is now in RealFlight! This tiny but sophisticated quadcopter is amazingly stable, making it both easy and extremely fun to fly. Try it yourself and see what the fuss is about!
See the full release notes below for more info, and please let us know if you discover any new bugs.
This version is compatible with 6.50.014 for multiplayer.
Perform the following steps to obtain the update:
Start the RealFlight 6 Launcher
Click Additional Options, then Technical Support
Click Enter Tech Support Code
Enter the following code: B#7fh9a355444y (If successful, you will see a message saying "You are now registered to use the Public Beta site until the new version is posted to official download site.")
Go back to the main Launcher menu and click Registration/Updates
Make sure that in the bottom left corner it says Temporary Public Beta. If not, try reentering the code
Click Update to Latest Version; alternatively, click Update to Specific Version, choose 6.50.016 from the list, and click OK.
The LauncherHelper will need to restart partway through this process. Answer "Yes" when it asks if you want to continue downloading the new version. When this process is finished, you will have the latest available version of RealFlight 6.
NEW FEATURES:
Heli-Max 1SQ
FIXES/IMPROVEMENTS:
Aircraft Editor: Engine components have an Engine Sound Volume property
 樓主| 發表於 2013年2月20日 12:48 PM | 顯示全部樓層
RealFlight version 6.50.014 is now public
Version 6.50.014 is now available as a free public release. It includes new content and fixes.
Make way for the Gaui X7! Enjoy rock-solid 3D performance from this 700 class heli.
See the full release notes below for more info.
Note that this update is cumulative. As long as you obtain the update via the Launcher, you do not need to update to any earlier/in-between versions first.
NEW FEATURES:
Gaui X7
New airport objects to use in your own airports:
Silver Trailer, Desert Cliff - Slope 1, Grassy Cliff - Slope 1, Desert Boulder Group - Large, Desert Boulder Group 1, Desert Boulder Group 2, Desert Boulder Group 3, Mossy Boulder Group - Large, Mossy Boulder Group 1, Mossy Boulder Group 2, Mossy Boulder Group 3
FIXES/IMPROVEMENTS:
Fixed a crash that occurred when running RealFlight at high resolutions, such as 5760x1200.
Fixed a memory leak in the Quick Edit dialog
Various collision system improvements. The most obvious change is the dramatic reduction of heli skid jittering while spooled up on 3D runways
Aircraft fuselages fall to earth without any slowdown after a midair breakapart, regardless of whether other pieces reach the ground first
Environmental reflections are reduced on the inside of smoked glass canopies
Import/Export: The default preview image for exported EA/AV/CS files has a different background
The "Clear Aircraft Position" menu item is disabled unless a custom reset position is active
In the Scenarios quick select menu, the airport preview’s rotation is not reset after entering then canceling out of the color schemes menu
Keyboard shortcuts for opening a viewport with a specific onboard camera (ex: Ctrl + F4, Ctrl + F5) do not cause extra console messages to be displayed
Multiplayer: "Airport loaded" console messages on the client side display the correct airport name
Fixed graphical glitches on the back of the Gasoline Truck airport object
Technical support contact info is updated for German users
AIRCRAFT:
PAU 36% Edge 540: The rudder no longer affects flight after breaking off; all rudder control surface sections have the same name; and the horizontal stabilizer is slightly stronger
AIRPORTS:
Obstacle Course 3 (EP2): Fixed static heli airport object floating above the table and a ring object that was partially intersecting the ground
____________________
If you previously downloaded the 6.50.013 public beta, here's what is different in .014. For everyone else, this is irrelevant.
Gaui X7: Motor is idle at zero throttle in Normal flight mode.
[ 本帖最後由 技嘉 於 2013年2月23日 11:46 AM 編輯 ]
發表於 2013年5月28日 10:52 PM | 顯示全部樓層
請教大大一下,我更新完6.5怎麼不能玩了
 樓主| 發表於 2013年5月31日 06:49 PM | 顯示全部樓層
小畯 發表於 2013年5月28日 10:52 PM
序號要能激活 才能升級到6.5版~
那你的是 序號問題 還是密狗抓不到 ?
發表於 2013年6月2日 06:09 PM | 顯示全部樓層
技嘉 發表於 2013年5月31日 06:49 PM
序號要能激活 才能升級到6.5版~
那你的是 序號問題 還是密狗抓不到 ?
安裝到最後會停止安裝。但是在點g6要玩時面版圖會變成6.5,但是無法執行。會顯示錯誤代碼
GMT+8, 2026年4月15日 10:21 AM
