樓主: top8558
華科爾台灣總經銷針對DEVO10延遲上市與維修問題遲緩公告
發表於 2012年4月7日 02:26 AM | 顯示全部樓層
國外論壇
玩家A發言
"I have rx 801 installed in my 450 PRO FBL. But I am using it as a receiver. You need to install 3gx in order to work properly. Walkera stopped producing 801 - because some people complained that they lose the signal. So they made 802 with longer coaxial cables - so it will pick up signal at longer distances.
But honestly I need to tell you something. If you want to fly Genius or Mini CP - ok, they are very nice, very durable and perfect for indoor (living room, bedroom, office, etc...) but when if you want to set up 3gx and with walkera's receiver - in this case RX801 - you could have some problems as I did. First of all - the colors don't match (wires colors). So you need to experiment to make it work. It took me a while to make it properly. And after that experimenting and after your build you need to set up your transmitter. It's not an easy task. I am an experienced with programming - so it should be a piece of cake. But it wasn't. One word - walkera (made in china ) and align 3gx (made in taiwan) are not compatible. So you need time and patience to make it work. Finally I made it - but it was not easy. "
玩家B發言
No idea why the guy is having a problem. I have the exact same combo and I used the wiring from the manual. The only thing I did differently was to plug in the battery wire from 3GX NOT into the BATT port, but CH7, that did the trick. I also did the bind with my Devo 8 receiver separately, without 3GX, so I was sure I have a good bind.
http://helifreak.com/showthread.php?t=388762  原文傳送門
依據成功的國外飛友所說
You don't need an extra battery. Just plug the power cable from the 3GX unit to the aux3 channel on the reciver and it will power up. Don't plug it in the "batt" socket on the reciver. Then it won't bind. The power cable is included in the 450 package.
感覺有一點匪夷所思阿   把3GX的電源線接到接收上的aux3就能啟動了
http://www.helifreak.com/showthread.php?t=396067  配制圖
[ 本帖最後由 mgawiko 於 2012年4月7日 02:41 AM 編輯 ]
發表於 2012年4月7日 02:56 AM | 顯示全部樓層
原帖由 mgawiko 於 2012年4月7日 02:26 AM 發表
國外論壇
玩家A發言
"I have rx 801 installed in my 450 PRO FBL. But I am using it as a receiver. You need to install 3gx in order to work properly. Walkera stopped producing 801 - because some people  ...
大大您好~dveo8*+3gx啟動是沒問題~你剛說的方式~我的老師也測試過~
但~會瞬斷~no控~已經"目前"是無解的~~
我只為那位朋友默哀~好險我乖乖換控~他還對華排抱持希望~~所以今天又噴錢了~
其實~~呂董~~你賺小機的錢就好~我很贊同華排小機玩dveo8真的很好玩~但是沒事搞個大機的接收~不是高手級的手感~根本感受不到熄燈哪0.5秒的差別~
雖然不關我的事~~但是那個BEC的謊~~真的是可以騙新手~~但騙不過機子~因為根本沒這個動作~~
發表於 2012年4月7日 03:01 AM | 顯示全部樓層
我看過了,也爬過這文章了,插上aux3可以過電,可以飛,但是實際面上還是會有一些"斷電跟NO控的問題"而已啦!但我想好好飛!不想淪為試驗!我是超嫩超新!但不代表沒裝大腦,就算我技術不好,但我也期待我哪天我的兩根大拇指,也能像前輩像老手們,飛的厲害飛的快樂!哪個老手哪個前輩不是從新手練起來的?華牌如同那位國外的飛友說的,飛小機很讚!耐摔耐撞維修快!但上到450之後產生的問題還真的是一個腦人的問題!
[ 本帖最後由 peijong965 於 2012年4月7日 03:04 AM 編輯 ]
發表於 2012年4月7日 03:04 AM | 顯示全部樓層
原帖由 peijong965 於 2012年4月7日 03:01 AM 發表
但我想好好飛!不想淪為試驗!我是超嫩超新!但不代表沒裝大腦,就算我技師不好,但我也期待我哪天我的兩根大拇指,也能像前輩 ...
別氣~~氣到字都打錯~~就算我技"術"不好
 樓主| 發表於 2012年4月7日 03:35 AM | 顯示全部樓層
原帖由 明旂 於 2012年4月7日 03:04 AM 發表
您所提出的問題,小弟可全程配合試機20天,每天以20顆電池為限,20天內如果有摔毀您朋友的飛機,小弟賠他一台新的3gx450,並且如果真是大陸總公司所生產的802有問題,我們一定替飛友們要個交代,整個20天試機過程將全程錄影,小弟電話您有,可直接聯繫,還是一句話問題是用來解決的,經銷商是生產廠與消費者的溝通橋樑,我們雖然不是最好的,但我們努力成為最好的團隊,   呂先生 敬上
發表於 2012年4月7日 09:16 AM | 顯示全部樓層
Dear呂總:謝謝你超有耐心的願意這樣花時間在經營3D直昇機,個人也感受的到你的努力跟在這塊的市場經營的熱情,也感受到這份熱情是來自於"事業的打拼"!你的努力跟市場開拓的成績大家有目共睹,但小弟只是個"嫩B不上道的新人",我也將我的熱情注入在直昇機上頭,親自+飛友的測試飛行也不下四五十趟次,可能還更多,已經將結果免費奉上了,呂總對自家產品深具信心不為動搖,小弟深感敬意,也因你這份信心跟堅持才繼續試下去,再次把清晰的狀況回報給呂總,仍然被覺得不可能!既然呂總這麼堅持在自家的事業之中,我也不好意思說的太多!
但你要一個新手新組的450給你測試20天,這!新手已經搞了快一個月拼命的修,還不夠,還需要借機子給你測試耗損,然後默默的等20天,你覺得20天後這新手還在嗎?新手不是免費的試機手、飛手、維修手,新手就是新手,新手容易發現問題,提著機子到處問,到處跑的新手,問到後面才會長大變老手,我可能真的太嫩,但我是真的還沒聽過新手試機、借機、等待可以變老手的。
所以呢?我告訴你的答案"Devo8S+3GX=完全不相容"是事實,也不只我發生,一堆飛友無論國內國外都有相同的問題,但你想繼續測試,我沒辦法陪你搞了!
最後!祝福你的堅強團隊能夠找出或看到問題的所在!謝謝
GMT+8, 2025年12月30日 07:30 PM
