查看: 872|回復: 1
Rave Ballistic FSO
發表於 2012年2月9日 09:45 AM | 顯示全部樓層 |閱讀模式
Rave Ballistic FSO
The long awaited special edition version of the popular Rave ENV 700.
Features in addition to the standard ENV:
- Electric Specific design
- Sliding Battery Tray
- Direct servo drive
- Helical Main Gear  (K1005 version)
- Helical Steel Tail Gears (K1005 version)
… and several other performance enhancements
Order Number & Pricing:
ND-YR7-K1005
USD $949.99-
ND-YR7-K1006
USD $849.99-
FAQ
What is FSO?
FSO is a special edition machine.
It will be sold only on a "Factory Special Order” basis.  We will work to fill the orders as quickly as possible.
Do the FSO and the ENV share parts?
Yes! These helis share a majority of the same parts and will be inter-changeable. That being said, all parts will remain in stock, ENV and Ballistic both.
Will the Ballistic be available for a limited time only?
No! The Ballistic is here to stay!
What are the kit differences?
The K1005 has helical cut main gears and has helical steel tail gears.
The K1006 has the standard plastic gear set, identical to the ENV.
Specs:
Length: 1340mm
Height: 420mm
Main Blade Length: 690-710mm
Main Rotor Diameter: 1,531-1,571mm
Tail Blade Length: 105-110mm
Tail Rotor Diameter: 294.5mm
Main Gear: Helical 130 Tooth Mod 1
Autorotation Tail Drive Gear: 118 Tooth Mod 1
Tail Miter Gears: Steel Helical 19 Tooth Mod 1
Also includes:
Carbon Fiber Frames
Painted Fiberglass Canopy
Aluminum Tail Boom
Steel Helical Tail Gears
Helical Main Gear
Carbon Tail Gear Box
Boom Support Bridge
Velcro Straps
ESC Front/Top Mount
Boom-Mounted Tail Servo
Dual-Support Tail Control Arm
說明書
http://issuu.com/youngbloodent/docs/ballistic_fso_manual_eng/3
上一篇:LOGO 600 SE 套裝 配5020-450KV
下一篇:Logo 600 se 組裝問題
 樓主| 發表於 2012年2月11日 11:28 AM | 顯示全部樓層
有現貨
GMT+8, 2025年12月10日 11:40 PM
