樓主: kylehuang
小野人(savage xs)一問
發表於 2012年2月5日 08:56 PM | 顯示全部樓層
小野人不是一無是處? 那是看個人   我就有一台小野人 滿不錯玩   玩的時候 是否太暴力要看自已   我都用11.1去玩 久久給它暴力一兩次 目前車體都很好     希望這點小小建議對你有幫助
發表於 2012年2月5日 09:09 PM | 顯示全部樓層
聽說小野人齒輪方面比較容易出問題.....如果不會暴力玩..不需要破路性.....小野人或許還可以接受....
但如果你想玩暴力..破路性高....那請選擇大野人...或是較便宜的雷虎MT-4 G3  .........
 樓主| 發表於 2012年2月5日 09:23 PM | 顯示全部樓層
原帖由 gv9757 於 2012年2月5日 09:09 PM 發表 聽說小野人齒輪方面比較容易出問題.....如果不會暴力玩..不需要破路性.....小野人或許還可以接受....但如果你想玩暴力..破路性高....那請選擇大野人...或是較便宜的雷虎MT-4 G3  ......... ...
謝謝各位大大的回覆,剛剛去看了HPI的網站,如果要買大野人(跑電的),買那個版本比較超值?(我有一個遙控器,一個6000mah,7.4v的鋰電池)
 樓主| 發表於 2012年2月5日 09:30 PM | 顯示全部樓層
你們有沒有看到? 大野人有KIT版?!
The Savage XS Gets the SS Kit Treatment!
Immediately after the Savage XS was released, our most hardcore fans started asking when the kit version would be available! Patience, we told them, let us get a few options parts released first! Well, now we've got a growing range of hot option parts released and the Savage XS SS is here!
Starting with the base Savage XS, we supply all the parts in a DIY build-it-yourself kit. Break out the tools, turn up the music and hide the phone - it's building time! Our fully illustrated instruction manual takes you step by step to build the Savage XS to your exact specs. Full-size part references and exploded views help you get the kit built quickly and without fuss.
As a bonus, the Savage XS SS includes fantastic option parts to get you started on the customizations! For some extra bling you get aluminum shock absorbers with orange-anodized tops, bottoms and shock collars. A set of front and rear universal driveshafts give you extra efficiency and durability. For quick camber adjustments you also get a full set of adjustable turnbuckles. You can even add extra option parts as you build up the kit!
Finally, you get to choose the exact electronics that go in the truck. Choose a quick servo for fast, nimble action, or go with a powerful servo for stunt work. Fit in a 2S-capable motor/speed controller set for all-around action and speed run, or go totally mental with a 3S-capable combination!
It's your choice with the Savage XS SS!
  • Self-build SS kit
  • Fits standard size 1/10th scale electronics of your choice
  • Waterproof receiver box
  • Aluminum shocks with threaded bodies
  • Orange-anodized shock hardware
  • All-metal bulletproof drivetrain
  • Front and rear universal driveshafts
  • Tough steel adjustable turnbuckles
  • 2.2" Savage XS tires
  • New design 6-spoke chrome-plated wheels
  • Shock towers have multiple shock mounting positions
  • Quick access to the front or rear differential by removing just 4 screws
  • Cam type servo saver
  • Spacious battery box w/locking battery box door
  • All socket head hardware
  • Dual pad slipper clutch
  • Full set of ball bearings
  • Aluminum motor plate with 4 motor mounting positions
  • Aluminum hex hubs
  • TVP (Twin Vertical Plate) chassis
  • Integrated chassis carry handle
  • Tough 4-gear differentials
  • Aluminum front and rear suspension braces
  • Stainless steel bulkhead lower plates
  • Front and rear skid plate bumpers
[ 本帖最後由 kylehuang 於 2012年2月5日 09:39 PM 編輯 ]
 樓主| 發表於 2012年2月5日 09:33 PM | 顯示全部樓層
原帖由 kylehuang 於 2012年2月5日 09:30 PM 發表 你們有沒有看到? 大野人有KIT版?!#107821 Savage XS SS Kit654941The Savage XS Gets the SS Kit Treatment!Immediately after the Savage XS was released, our most hardcore fans started asking whe ...
歐,看錯拍謝。是小的。
GMT+8, 2026年4月28日 01:41 PM
