查看: 1207|回復: 2
外國統計結果
發表於 2011年8月25日 03:14 PM | 顯示全部樓層 |閱讀模式
 樓主| 發表於 2011年8月26日 09:49 AM | 顯示全部樓層
Version 5.2 Release at 1st September 2011
25 August, 2011 - 23:14 — ulrich
At the 1st of September we release the 5.2 Firmware and PC Software to our customers. Since it is a minor enhancement, the update is free for all 5.x users.
The 5.2 will be available as online update for the express owners too, which will still have the same functionality as express before, but with the new 5.2 enhancements at the algorithms.
Whats new:
The "pro" version of the mini will now have a governor too, same as the fullsize one. Due to limited ports at the mini unit the governor can only be used in combination with a Spektrum, a s-Bus or M-Link or a classic single line reciver. An external reciver with governor is not possible.
The Governor has been massively rewoked, mainly to better support electric governing. This gives a completely new option with most simple electric speedcontrollers. So even a simple controller turns into a high quality governor.
Setting up an electric governor has been greatly simplified. The default settings will match most usual installations, so there is no extensive tuning process needed.
The Integration between the governor an the rest of the algorithms has been improoved, so the complete control loop works smoother and quicker.
New security functions avoid unintended hot starts of the motor, which can turn into dangerous with electrics. This adds top level protection to simple ESC´s as well.
The piruette compensation has been improved. Complex moves will be smoother and more precise now.
Both versions will be available in paralell, so you can choose between 5.1 and 5.2 at any time.
The Update prcoess will be performed by a new pc software with the known method. The location of the software will be announced at the 1th. The settings will be taken over, so no new programming needed, just as you know from former updates.
Mini VBar 也有定速了
GMT+8, 2025年11月14日 06:08 PM
