查看: 459387|回復: 0
【分享】T14Z軟体昇級((附上軟体))
發表於 2006年3月2日 09:31 PM | 顯示全部樓層 |閱讀模式
我的剛昇級好,還不錯用
【New functions】        Software version :  Editor Ver.1.0.6 , Encoder Ver.1.13            1M23N14825
Hardware setting
This function adjusts the sticks, switches, and trimmer characteristics.
● System menu
● Push the “Hardware setting” button on the system menu. The LCD appears as shown below. The hardware reverse function is same as before the update.
Stick setting
This function adjusts the sticks' response and hysteresis (null control). You can set your preferred control feel for each flight condition.
Push the “stick setting” button on the hardware setting screen. The LCD appears as shown below.
Adjusting the stick response
1. Push the response button for the stick you wish to adjust. The rate adjustment button will appear.
2. Adjust the stick response by pushing the rate button.
 Default: 4
 Adjustment range is: 1-32 (the greater value gives slower response)
Adjusting the hysteresis:
1. Push the hysteresis button for the stick you wish to adjust. The rate adjustment button will appear.
2. Adjust the hysteresis by pushing the rate button.
 Default: 1
 Adjusting ranges: 0-32 (the greater values increase hysteresis)
Push the “stick setting” button after finishing the setting.
Swash mixing (Heli mixing)
The trim selection button is added.
● Trim on/off setting:
You can select mixing characteristics to be either with or without trim.
When the model or frequency is changed:
The current software requires you to turn off the power switch when the model or frequency is changed. The new version moves to the transmission confirmation screen after that operation. You are not required to turn off the power switch, so that immediate operation is available.
Change in the way buttons in the “Curve Setting”, “Model Select” and “Condition Select” screens are shown.
The previous version displayed inoperative buttons in grey.  In the new version they are completely eliminated from the screen.
(Example: Curve setting screen)
The new version shows the rate adjustment buttons at full brightness (such as the arrow and reset buttons) when an item that needs rate adjustment is selected.
However, it does not show them when an item that does not need rate adjustment is selected.
                             (Old version)                    (New version)
附上軟体,有14動的人可以昇級喔!!
http://myweb.hinet.net/home1/fiyboy/12-08-05-T14MZ-update.zip
[ 本帖最後由 矸仔 於 2006年3月9日 08:09 PM 編輯 ]
上一篇:【求助】香港來的機友
下一篇:【貼圖】霹靂腰包
GMT+8, 2025年12月10日 12:57 PM
