樓主: 傘王弟
台南武聖飛場討論區
發表於 2011年8月21日 12:06 PM | 顯示全部樓層
今天收到卡斯特公司寄來的信,大概看一下,就是HV系列都要更新不能用啊
ICE HV, Mamba XL & Hydra Ice HV
Warning & Recall advisory 2011-03
Aug 20, 2011
The performance of a component used in the Castle ICE HV 60, ICE HV 80, ICE HV 120, ICE HV 160,  Mamba XL and HYDRA ICE HV controllers has changed from the original specifications for that part. This tolerance change may lead to failure of the affected controllers.
For your safety, we request that all customers cease operation of these controllers immediately.  Send all of these controllers back to Castle for modifications required to improve the safety and reliability of these products. This recall includes all controllers labeled as V3. There are no charges associated with this modification.
The only controllers that are properly modified and are approved for operation will be labeled clearly as ICE HV (Amp Rating) 2, Mamba XL 2 & HYDRA ICE HV 2.
We understand that you may not wish to return your controller. Those that have served you well are likely to continue doing so; however, controllers that you may have recently purchased should be assumed to be assembled with the problem components.
If you insist on using these controllers, please be advised that the risks of continued usage begin with severe burns to you and/or others, as well as property damage to your RC vehicle or surroundings. Please wear fire-proof gloves when connecting any HV controllers that use 8 or 10 gauge wire to their power source.
唉~那我600該怎辦哩??
發表於 2011年8月21日 01:18 PM | 顯示全部樓層
賣掉換好X.......沒有啦~我來亂的
發表於 2011年8月21日 01:43 PM | 顯示全部樓層
回復 600樓 wtb621 的帖子
請問~~~那是T牌的電池嗎>??
發表於 2011年8月21日 02:10 PM | 顯示全部樓層
回復 609樓 ADER 的帖子
代答:電池是使用T牌22.2v 5000mah 20c的電池~謝謝感恩~
發表於 2011年8月21日 09:50 PM | 顯示全部樓層
來放幾張今日飛場的照片~~~
發表於 2011年8月21日 10:26 PM | 顯示全部樓層
08/21〈日〉晴天~武聖飛場花絮
*夭壽貪吃!居然忘了拍堯爸帶來的、超級溫馨愛心肉包!真歹勢!粉好吃!謝謝堯爸!也謝謝朝哥大大的!冰涼消暑36味涼茶!
GMT+8, 2026年4月19日 03:47 PM
