查看: 807971|回復: 3
RealFlight G2
發表於 2001年9月24日 07:05 PM | 顯示全部樓層 |閱讀模式
RealFlight G2能否在Windows 2000上執行呢?
上一篇:我有一套 CSM 9.1的軟體..請問可以升級嗎????
下一篇:csm 最新的板本,是不是很接近實機?
發表於 2001年9月24日 10:09 PM | 顯示全部樓層
原文為FREYA發表。
可以,只是安裝上要小心一點,關閉其他程式再安裝,2000龜毛很多,顯示卡驅動程式只要一點點不對便無法執行,很龜毛就是了啦!
我就是用WIN2000在玩
我已經很久沒飛了........
發表於 2001年9月25日 01:10 AM | 顯示全部樓層
我也裝過...其實沒那麼難啦......
以下是RealFlight G2針對Win2000的安裝注意事項...提供給您參考參考~~~
<hr>
<pre>
Instructions for Manually Installing the Transmitter Interface Drivers under Windows 2000
4/4/2001
This document is applicable to RealFlight Classic, Deluxe and G2.  If you are running Windows 95, 98, or ME, this document doesn’t apply to you.
If you are having problems getting error messages when starting RealFlight Classic, Deluxe, or G2, then you can try the following.
·        First Try the instructions below and manually install the driver.  Then start RealFlight.
·        If this doesn’t work, you may have to completely uninstall RealFlight, reinstall RealFlight and apply all the patches (BEFORE RUNNING REALFLIGHT), and then manually install this driver.
To manually install the transmitter interface adapter under Windows 2000, do the following steps:8879576
1.        If you have G2, then update using the RealFlight Control Panel. That will get you this file and the necessary drivers.  If you have RealFlight Classic or Deluxe, then download the latest version of that program from www.realflight.com.  That will also contain this document and the necessary drivers.
2.        Go to the Start Menu/Settings/Control Panel and choose Add/Remove Hardware
3.        Click Next
4.        Choose Add/Troubleshoot Device, then click Next.
5.        It may take a second to scan Plug-n-Play devices.  After it is done, it will show the following dialog.  Click Add a New Device and click Next.
6.        Click No, I want to Select the hardware from a list, and then click Next.
7.        Choose Other Devices and click Next.
8.        Click Have Disk…
9.        Type in the location that has Realf.inf and Realf.sys (This will be in c:program files
ealflight for most people).  Make sure you are updated to the latest version of RealFlight before you do this step.  Then click OK.
10.        The following dialog should appear.  Then click Next.  If there was a problem finding the driver, it would show a different dialog.  If this is the case, see step 1 on how to get the latest drivers.
11.        The following dialog will appear.  Click OK.
12.        The following dialog will appear, click Next.
13.        The following dialog will appear, click Resources…
14.        The following dialog will appear.  Click Use Automatic Settings and click OK.
15.        You are done, you can now launch RealFlight.
</pre>
<hr>
<font size=4></font id=size4><font color=navy></font id=navy>
<font size="1" color="blue">Edited by - jjh 重新編輯於 2001/09/25  01:11:36 AM
發表於 2001年9月25日 02:24 AM | 顯示全部樓層
我的作業系統是Win98,只因為不小心使用了較高級的介面卡,
顯示卡WinFast GeForce2 GTS +音效卡 SoundBlaster Live娛樂版,
為了玩RealFlight,真使我吃足了苦頭.
首先安裝好RealFlight後,玩一玩就當機,
畫面就死在那兒.花了二天的時間才搞定,
包括重新安裝Win98,更新顯示卡BIOS及DRIVER,
最後還必須將背景音樂關閉,才可正常執行.
再來是安裝RealFlight G2,執行後畫面一遍空白,
什麼東西也看不到.到RealFlight的網站上看一看才知道,
原來使用GeForce2 GTS的人必須安裝更新程式.
安裝更新程式後畫面終於正常了,
可是玩一玩又當機了.最後必須到nVIDIA的網站
下載最新的DRIVER才可正常執行.
前後共花了三天的時間,才看到RealFlight G2
的效果,1024*768 16bit的畫面,
每秒至少能顯示60幾頁.
GeForce2 GTS的錢總算沒白花.
<font size="1" color="blue">Edited by - rowland 重新編輯於 2001/09/25  02:26:57 AM
GMT+8, 2025年12月31日 02:54 AM
