樓主: Bono7359
Insane F1
 樓主| 發表於 2010年1月23日 11:21 AM | 顯示全部樓層
回復 6樓 julia0826 的帖子
Julia大,我還再和Insane的老闆Jeff確認中,這艘會在下週Atlanta Winter Nats中展示.
 樓主| 發表於 2010年1月23日 11:29 AM | 顯示全部樓層
回復 6樓 julia0826 的帖子
Julia, Insane/Jeff's reply as below. FYI.
The hull was designed around the lawless outboard drive.
I am working on my own affordable pipe which will be available shortly after the release of the hull.
The design of the hull was inspired by the newer champ boats. A special thanks to Dan Elison for helping with the mold. The wet well on the back of hull moves the cg forward. I figured out where the radio box needed to be located, so that is why I integrated it into the hull. Again, I designed this hull so that the average boater would not have to figure this out. The radio box can also be cut away from the hull and moved with very little effort.
GMT+8, 2026年4月20日 01:26 AM
