查看: 304953|回復: 1
【分享】JR-X347改CCPM有誰會翻譯
發表於 2004年5月30日 09:17 PM | 顯示全部樓層 |閱讀模式
Re: JR X347 and ccpm mix
      #30218 - 11/19/03 12:38 PM   Edit     Reply     Quote
IF you use this procedure, be very careful as to watch what you are doing, you can really mess up the radio!
Here goes.
- Start with flipping your GEAR switch to the rear position.
- Turn on the radio with the two UP/ Down keys depressed (just as if you were going to reselect another model).
-Scroll to model RESET.
-Now pull the gear switch forward and then press the DATA + key , then push the gear switch back and press the DATA - key. Repeat this fairly quicky witout stumbling! You must develop a rhythum (if you will) and continue to do this untill you hear a BEEP. If you don't hear the beep after a couple of minutes, start over and try again untill you get the BEEP.
- When you get the beep, the screen will change.
- Use one of the two UP/Down buttons to scroll to the screen that says BATTERY.
-Push the CH button untill you see "swash" or "swsmx" and you will see that it is inhibited. Hit the DATA + or - key to activate the swash mix function.
- now hit the two UP/Down keys to go back to the regular screen.
-You can now see the 3 different swash mix types in your set up menu.
Hope this helps!!!
PLEASE BE CAREFUL DOING THIS!!!!! Don't be tempted to wander around in this mode, there is a lot of stuff you can change!!
Isaac
上一篇:【貼圖】雙主旋翼直昇機
下一篇:【分享】電動飛機之飛行場地(高縣)
發表於 2004年6月3日 11:23 AM | 顯示全部樓層
不是已經給你翻譯過了 貼在電動直昇機討論區了??
GMT+8, 2025年12月4日 08:39 PM
