樓主: Tony哥
[空/飛機] [售價3500~10000] 出清 EZ Topflite等收藏 都全新未組裝
發表於 2018年11月2日 09:23 PM | 顯示全部樓層
那我應該沒這個手藝,讓賢好了
 樓主| 發表於 2018年11月2日 09:30 PM 來自手機 | 顯示全部樓層
P40E重新釋出囉
 樓主| 發表於 2018年11月2日 09:42 PM 來自手機 | 顯示全部樓層
alens611 發表於 2018年11月2日 06:21 PM
請問p40e那台,翼展多長
        Tech Notice
P-40E Warhawk Gold Edition
WWII's Flying Tiger—in a kit that makes accuracy seem effortless
SPECIFICATIONS:
Stock Number: TOPA0120
Wingspan: 64 in (1625 mm)
Wing Area: 597 in² (45 dm²)
Weight: 8-10.5 lb (3.63-4.76 kg)
Fuselage Length: 54.25 in (1376 mm)
Engine Required: 2-stroke .61-.90 cu in or 4-stroke .91-1.20 cu in
Radio Required: 4-7 channel w/4-8 servos
Suggested MonoKote Colors: Tan and Olive Drab.
Recommended Scale Options: Warbird Pilot; Static Display Prop; Fuel Drop Tank; In-Cowl Muffler (TOPQ7915)—requires header TOPQ7920 for O.S. engines
發表於 2018年11月3日 12:17 AM 來自手機 | 顯示全部樓層
收F4u排1
發表於 2018年11月3日 12:22 AM 來自手機 | 顯示全部樓層
F4u請說明一下尺寸引擎
[/td][/tr] [/table] [/td][/tr] [/table]  詳情 回復 發表於 2018年11月3日 12:04 PM
 樓主| 發表於 2018年11月3日 12:04 PM | 顯示全部樓層
rcroot 發表於 2018年11月3日 12:22 AM
F4u請說明一下尺寸引擎
This .40 - sized Corsair is 90% prebuilt - 100% impressive!Even if you have no time for building, you can enjoy a classic warbird—it's the first-ever .40-sized Corsair ARF that's scale! All of the full-size fighter's unique contours have been accurately reproduced, and since the major sections are factory-built and covered, it can be flight-ready in just a few evenings.
  • Elevator and rudder control linkages are internally concealed to more faithfully reproduce the Corsair's scale lines
  • Standard fixed landing gear is included, but the model will accept 90° rotating retracts for added realism (Hobbico Mechanical 90° Rotating Retracts, HCAP4060, recommended)
  • The round cowl perfectly fits the fuselage, and, like all the plastic parts in the kit, comes pre-painted to match the plane's colors
  • Top-quality Great Planes hardware and a step-by-step, photo-illustrated instruction manual ease the completion process
[size=0.9em]SPECIFICATIONS:
Stock Number:
GPMA1530
Wingspan: 55.75 in (1415 mm)
Wing Area: 604 in² (39 dm²)
Weight: 8.3 lb (3.76 kg)
Fuselage Length: 45.75 in (1160 mm)
Requires: 2-stroke .45-.52 cu in (7.5-8.5 cc) or 4-stroke .70-.80 cu in (11.5-13 cc) engine, prop and 4-channel radio (5-channel if flown with optional retracts)
[size=0.8em]Contact Us
[size=0.8em]Service Center
[size=0.8em]Promotions
GMT+8, 2026年11月12日 08:53 AM
