樓主: 童基生
TOP RC SPITFIRE 噴火式戰鬥機
 樓主| 發表於 2016年4月12日 01:09 AM | 顯示全部樓層
這兩台也很棒
 樓主| 發表於 2016年4月13日 11:36 PM | 顯示全部樓層
這台150cc的海貍也很棒 是 程揚CYMODEL的飛機
 樓主| 發表於 2016年6月4日 12:31 AM | 顯示全部樓層
Specification:
Wing Span: 2058mm/81in
Length: Specification:
Length: 1715mm/67.5in
Flying Weight: 7.6kg
Wing area: 74.95 dm2
Engine: 35cc
R/C System: 2.4Ghz 6ch
Servo: GP *7 ; EP * 6
Battery: LI-PO 5S*2 5000mAh 30C
ESC: 120A High voltage Brushless ESC 1715mm/67.5in
FlyingSpecification:
Engine: 35cc
ESC: 120A High voltage Brushless ESC Weight: 7.6kg
Engine: 35cc
ESC: 120A High voltage Brushless ESC :
Flying Specification:
Engine: 35cc
Packing size: 140.5*37*54
Description:
1. Full composite construction , sandwichrumpf by Airex, balsa & epoxy.
2. All surface prepainted,decals applied and clear coated
3. Scale cockpit, scale exhaust included.
4. Detachable Scale gun set and antenna included;
5. Detachable main wing and tailplane for easy transportation;
6. Removable hatch on fuselage for easy access into the plane and change accessories;
7. Functional flaps for smooth landing.
8. High quality CNC Alu push rod included
9. More than 95% assembled complete in factory.
10.Can be powered by engine or motor.
11.12mm corrugated board boxes packing to protect the parts to avoid damaged.Weight: 7.6kg
Engine: 35cc
Description:
GMT+8, 2026年11月11日 12:10 PM
