發表於 2002年7月1日 07:32 PM
顯示全部樓層
Dear Julian,
You have tried inverted fight with my 1:3.75 voll GFK ASW28.
As you'd said, the lift is very weak in Summer. So assume no lifting force act on the wings. The friction between the steel bar is good enough to hold up the wing.
Don't be afraid just do it. But I strongly suggest not to try inverted fight in scale, since it's too danger.
The thermal ability of PG' 28 is ok, I've tried once in Long Tam. I don't know much on HF'28.
In my opinion, the most important is not the thermal ability of your plane. For a sailplane which can take off suffessfully the flying field is very important.
You can't expect a 1:3.75 ASW28 can lift up to sky from yur hand. It need "runway", the distance for the sailplane to accelerate to a minium speed which can lift you plane up. It's the most dangerous time for a large sailplane, ortherwise you can take up via aerotow.
I'll not fly bigger than 1:4 scale ship in Summer, because it's too danger.
Call Chan Chi Ping, he will give you some advice of your HF.
Good luck , good flying & happy landing.
Alex Chan. |
