樓主: jrwei
Joysway 8805 Dragon Force RTR
 樓主| 發表於 2014年5月15日 01:42 PM | 顯示全部樓層
DF對於帆的建造制訂得很嚴格,連帆骨的位置與尺寸都有明確規定,
不過就是因為制訂得很明確,比較有規則可依循及競賽的公平性.
Section H - Sails
H.1 Usage
A sail from one rig shall not be used with another sized rig.
H.2 Construction
Construction shall be a soft sail of a single ply.
The Jib and Mainsail of any given rig size shall be constructed
from the same ply.
All sails shall be constructed of a single panel with no seams
and the maker shall not try to introduce camber (shape) into the
sail by means of heat or force.
The sails shall be attached to the rigging and spars by means of
a single hole positioned within 10mm of each sail corner point
(points A, C & E Jib, A, G & L Mainsail) and three other suitable
positions along the mainsail luff. Metal eyelets may be used to
reinforce these holes.
H.3 Battens
A & B Mainsails - Shall have four battens with their outer ends
positioned within 5mm of points H, I, J & K . The top batten shall
have a maximum length of 100mm and the lower three battens a maximum
length of 50mm. Maximum width 12mm.
C Mainsail - Shall have three battens with their outer ends positioned
within 5mm of points I, J & K. Maximum length of 50mm. Maximum width 12mm.
Jibs - May have two battens of maximum length 50mm and maximum width 12mm
with their outer ends positioned anywhere along the Jib leech (back edge).
H.4 Reinforcement Patches.
Reinforcement patches may be used at the sail corners, batten ends and
mainsail luff attachment points. These shall be of self-adhesive material
of not more than four layers.
Sail corner reinforcement must fit within an 80mm radius of the sail corner point.
Mainsail luff attachment point patches and batten end patches, at either
end of the batten, shall fit within a circle of 20mm diameter
Mainsail luff tabling is not permitted.
H.5 Jib Luff
The Jib Luff shall form a straight line between points A & C.
Tabling at the luff (front edge) shall form a pocket for the Forestay. Maximum
width of tabling shall be 12mm. Tabling forms part of the sail area and must
fit within the sail dimensions. Tabling shall be one, continuous pocket finishing
within 10mm of points A & C.
H.6 Leech Profile
Jib - The Jib leech shall form a straight line between points D & E.
Mainsail - The Mainsail leech shall be formed by a series of straight lines beween
the leech points G, H, I, J, K & L.
H.7 Foot Profile
Jib - The Jib foot shall form a straight line between points A & E.
Mainsail - The Mainsail foot shall form a fair curve between points A & L with the
point of maximum curvature M as described in Diagram 2.
H.8 Mainsail Luff Curve
The amount of luff curve is optional, but must be included in the sail cross widths
as described in Diagram 1 and Table 1
Dragon Force Restricted Class Rules 2014 Version 1.3
H.9 Sail Numbering
Sail numbering shall conform to the RG65 International Class Rule (see website www.rg65.org)
with the permitted change to allow the use of three digits.
H.10 Class Emblem
The RG65 class emblem shall be used in accordance with the RG65 International Class Rule.
H.11 Sail Decoration
Sails may be decorated using ink, but markings shall not interfere with easy identification
of the sail numbers, or national letters if fitted.
H.12 Sail Manufacturer Logo
A sail manufacturer logo may be fitted on one or both sides of the sails and must be positioned
within a radius of 80mm from the tack point A.
資料來源:Dragon Force Restricted Class Rules 2014 Version 1.3
這也是這個級別好玩的地方 把硬體的影響降到最低. 剩下"人"這個因素 就像老外說的 , "The man behind the stick" 才是最重要的元素  詳情 回復 發表於 2014年5月15日 05:44 PM
發表於 2014年5月15日 05:44 PM | 顯示全部樓層
本帖最後由 linuschao0202 於 2014年5月15日 06:13 PM 編輯
jrwei 發表於 2014年5月15日 01:42 PM
不過就是因為制訂得很明確,比較有規則可依循 ...
這也是這個級別好玩的地方
才是最重要的元素
在國外, DF是有跟一般的RG 65同組比賽, 上個月才剛結束的2014 RG65
US National Championship Regatta就是如此, 參賽者22名, DF有11艘.
DF最好的名次跑到第5名. 第一名的船售價超過NTD 60,000.
說真的, 如果能用DF跑贏其他價格是它好幾倍的船也是一件很爽的事
希望有朝一日台灣也能辦這類賽事與創立CLUB  詳情 回復 發表於 2014年5月15日 09:05 PM
 樓主| 發表於 2014年5月15日 09:05 PM 來自手機 | 顯示全部樓層
linuschao0202 發表於 2014年5月15日 05:44 PM
這也是這個級別好玩的地方
就像老外說的 , "The man behind the  ...
我覺得可能辦.只要符合現況但規模隨意.那就可以比賽.  詳情 回復 發表於 2014年5月15日 10:22 PM
不可能啦!...我努力過了!... 別做夢了!...不可能的啦!...  詳情 回復 發表於 2014年5月15日 09:31 PM
發表於 2014年5月15日 09:31 PM | 顯示全部樓層
jrwei 發表於 2014年5月15日 09:05 PM
不可能啦!...我努力過了!...
別做夢了!...不可能的啦!...
+1大...別那麼激動嘛!  詳情 回復 發表於 2014年5月15日 09:41 PM
 樓主| 發表於 2014年5月15日 09:41 PM 來自手機 | 顯示全部樓層
9527+1 發表於 2014年5月15日 09:31 PM
不可能啦!...我努力過了!...
別做夢了!...不可能的啦!...
+1大...別那麼激動嘛!
發表於 2014年5月15日 10:22 PM | 顯示全部樓層
其實,蓮池潭早就比過多場的RG65比賽了。  詳情 回復 發表於 2014年5月15日 10:29 PM
GMT+8, 2026年11月20日 01:09 PM
