樓主: abc440404
美國未來四十年主力戰機 X-35
 樓主| 發表於 2006年10月15日 10:36 PM | 顯示全部樓層
如果有誤,歡迎指正,應該是本人只看 X-35 測試,單方自言其為未來四十年主力戰機,未加詳細研察以致有誤,對於您的說明謹此致謝.
發表於 2006年10月16日 12:13 AM | 顯示全部樓層
35不是垂直起降機嗎?
是用來取代海獵鷹的吧......
 樓主| 發表於 2006年10月16日 08:10 AM | 顯示全部樓層
原帖由 A-GO 於 2006年10月16日 12:13 AM 發表
35不是垂直起降機嗎?
是用來取代海獵鷹的吧......
X-35 Joint Strike Fighter Specifications
Primary Function:Strike fighter [Conventional Takeoff and Landing]
Contractor:Lockheed-Martin
Powerplant
One Pratt & Whitney F119-PW-100 derivative from F-22 Raptor
Dimensions
Length:45 feet
Wingspan:36 feet
Height:N/A
Weights
Empty:22,500 lbs
Maximum Takeoff:50,000 lbs
Performance
Speed:supersonic
Ceiling:N/A
Combat Radius:over 600 nautical miles
Armament
 樓主| 發表於 2006年10月16日 08:27 AM | 顯示全部樓層
35不是垂直起降機嗎?
是用來取代海獵鷹的吧......
DESCRIPTION:
The Joint Strike Fighter program was started to replace a myriad of aircraft for the US Air Force, US Navy, US Marines, and the British Royal Navy beginning around 2010. Since each branch hoping to acquire the JSF has different needs, each variant of the aircraft will be tailored to the requirements of that service. The USAF is planning to acquire some 1,760 conventional takeoff attack fighter variants to replace the F-16 and A-10 while the Navy and Marines are looking to replace older models of the F/A-18. The Navy's approximately 300 to 480 aircraft will be generally similar to the Air Force model but will carry more fuel for greater range. The Marines also need about 480 vertical/short takeoff and landing (V/STOL) aircraft to replace its fleet of AV-8B Harriers, so its version will feature a ducted lift-fan to assist in vertical flight. The Royal Navy is also interested in purchasing about 60 V/STOL models to replace the Harrier while the Royal Air Force plans to acquire another 90 to replace its Harrier fleet.
你們說的都沒錯它是取代多款舊型戰機.
發表於 2006年10月19日 01:28 PM | 顯示全部樓層
DISCOVERY裡有看過~~~~台灣加油!!~
發表於 2006年10月23日 01:19 PM | 顯示全部樓層
GMT+8, 2026年11月20日 12:27 PM
