樓主: 非常硬
[誠徵] 誠徵FUTABA-R6203SB接收機
發表於 2016年11月12日 12:39 AM | 顯示全部樓層
天蝎星4025 - 1100KV 无刷电机
适用于亚拓600E,RJX 600E 等600级直升机
Stator Diameter        40 mm(1.57 in)
Stator Thickness        25 mm(0.98 in)
No. of Stator Arms        12
Magnet Poles        10
Motor Wind        3T/3T Delta
Motor Wire        27-Strand 0.29mm
Motor Kv        1100KV RPM/Volt
No-Load Current (IO/10v)        3.19 Amps
Motor Resistance (RM)        0.008 Ohms
Max Continuous Current        100 Amps
Max Continuous Power        2200 Watts
Weight        354 Grams (10.79 oz)
Outside Diameter        49.98 mm (1.97 in)
Shaft Diameter        5.98 mm (0.24 in)
Body Length        51.8 mm (2.04 in)
Overall Shaft Length        83.7 mm (3.30 in)
Max Lipo Cell        6s
Peak Current        130 Amps (5 seconds)
Peak Continuous Power        2750 Watts (5 seconds)
Motor Timing        5deg
Drive Frequency        8kHz
Included in the Box
1 x Scorpion HKIII-4025-1100KV Motor
3 x Female Connectors
3 x Heat Shrink
4 x M3 Screws
GMT+8, 2026年11月18日 10:26 AM
