樓主: qw3663wq
這裡有多少人玩油車呀@@?
發表於 2006年11月1日 07:17 PM | 顯示全部樓層
有沒有那裡可以買到這一款車
各位大哥
不知道有那裡可以買到這一款車,請參考一下附件!
實在需要資訊。謝謝啦!
規格表如下:
sITAS VIENAS IS DIDESNIU, BET SU MECHANINE DEZE.
gth × Width × Height (mm): 1850×980×1080
Wheel Base(mm): 1150
Engine Type: Single cylinders、air-cooling、Fourth stroke
Start Mode: Electric
Power (Kw/r/min): 11/7500r/min
Max Torque (N.m/r/min): 17/6000r/min
Mini Ground Clearance (mm):  140
Max Speed: ≥60
Dry Weight(Kg): 150
Transmission Mode: Chain
Break Type(F/R) : Drum/Disc
Specification: 12 V 9 Ah
Climb Degree : ≥25°
Tank Capacity (L): 4L
Front Hanging: Double arm-swing
Rear Hanging : Integral
Specification of type: Front-wheel drive 19×7-8
                    Rear wheel 18×9.5-8
Cylinder Diameter*Journey(mm): 65.5×66.2
Displacement (ml): 223
Shift Gear: Six gear、manual clutch
Height of seats(mm): 740
Mini Turning radium(mm):  2000
Parking Trig: Press splash
Ignition Mode:  C.D.I
Loading Capacity(kg):  150
Engine Oil (L): 1.3
Gear Wheel oil (L):  0.3
Person: 1
Lubrication:  Press splash
Compression Proportion: 9.0:1
Gas Cylinder number:  1
Parking Dimension(mm):   1485×835×770
MODEL
MODEL
GMT+8, 2026年11月25日 04:14 AM
