樓主: 冰淇淋MM
新潜艇龙鲨照片录象
 樓主| 發表於 2006年11月21日 04:15 PM | 顯示全部樓層
We post DragonShark months ago.Many people build and sail this boat and give us many good advice.We found the VAC hull a bit weak for that speed boat and somebody fell difficult to build a VAC hull because of glue.
We gathered these advice and post new injection parts below,please note the differents between old and new version.
The new version is more strong and more easy to build.Every buyer still not build this boat can get new parts for free from us.it's a free update!Please contact sales@arkmodel.com,Thanks!
Old version's bow and rear hull is by 1mm ABS vacuum form,half parts.New version with 1.5mm injection ABS 1 piece.
Old mid-hull use PVC white tube,New's use transparent arclic.
Re-designed tail wimble,pre-fit 4 brass bearing,add 8 groove to fit with rear hull.
You can insert tail wimble into rear hull easily,insert dead against or turn 45 degree,that's you can build a Xrudder boat or a Cross rudder boat if you want.
Old rear hull need more than 1 hour to build,now you can build in 5 mins.
發表於 2007年1月22日 07:17 AM | 顯示全部樓層
不錯的一艘潛艇~
發表於 2007年1月22日 11:38 AM | 顯示全部樓層
Ebay....>>>>http://cgi.ebay.com/RC-RADIO-CON ... QrdZ1QQcmdZViewItem
好貴.....但我好喜歡
GMT+8, 2026年11月23日 12:47 AM
