樓主: 笑傲醬糊
詭異的失去動力..請老手們相助^^
發表於 2012年3月12日 07:25 PM | 顯示全部樓層
原帖由 wan0761 於 2012年3月12日 07:20 PM 發表
從選項裏的TIMER->TIME-.>時間的最後一項~改成TONE~即可!
TONE/VIBE~提示音+震動警示
TONE~只有提示音
VIBE~只有震動
感謝.....
 樓主| 發表於 2012年3月12日 11:59 PM | 顯示全部樓層
原帖由 wan0761 於 2012年3月12日 06:53 PM 發表
我的dx8也遇過跟你一樣奇怪現象...
開震動提示時~當提示開始(震動開始)就會有斷電現象!!
剛發生時一直無解!搞了好久...
一直到無意中將震動關閉後竟然就沒發生過了...
於是我拆開dx8將所有的接頭在按緊一次,尤其是發射模 ...
感謝前輩提供的方向.終於找出原因
的確是因為震動後才斷訊(剛剛用mcpx反覆測試過了).不過不同的是.我是電池的接頭好像有點氧化還是啥的.重插之後初步測試沒有斷訊了.但在震動時螢幕會閃爍.表示可能電力不足.接頭又氧化才造成斷訊.
真的感謝您提供的經驗分享.不然自己摸索真的不知摸索到何時.再次感謝
發表於 2012年3月13日 04:39 PM | 顯示全部樓層
如是震動問題接頭要再處理一下比較好,
必竟關掉震動功能僅是治標。
發表於 2012年3月14日 12:29 AM | 顯示全部樓層
不知道是否是以前召回過的問題
請看視頻 https://www.youtube.com/watch?v=C45Izp5qxX0&feature=related
及原廠說明
http://spektrumrc.com/Products/Support.aspx?ProdId=SPM8800
Recently, the Horizon Hobby Service Center has received a small number of reports from customers claiming un-commanded servo movements and loss of RF link during the activation of the vibrator motor in some DX8’s from the initial shipment.
Horizon requests that all DX8 customers with the Product ID (PID) HS008X or HS009X found in the battery compartment carefully check their radios to determine if their transmitter has this issue prior to flying.
Transmitters with a PID other than HS008X or HS009X are not affected by this bulletin.
If you have a DX8 with the affected PID, please perform the following test.
•Step 1: If your model is electric, unplug motor leads from ESC for safety.
•Step 2: In the function list, select Timer Screen and set a 0:10s Count Down timer to Tone/Vibe.
•Step 3: With model powered on and connection established, activate timer and observe servos for un-commanded movement and receiver for loss of RF link.
Should you find that your transmitter is affected by this issue, please contact your nearest Spektrum authorized service center to arrange for a free upgrade to your DX8 performed by a Horizon Hobby authorized Technician.
•Click here to complete the Spektrum DX8 Return Request form.
•You may also e-mail the Horizon Hobby Product Support team. Please type "DX8 Return Request Form" in the subject line.
Please include your shipping address, daytime phone number, and PID code from your Spektrum DX8 transmitter. Click here to e-mail Product Support.
•Horizon will pay for all ground shipping.
•If you have further questions, please call Horizon Hobby Product Support at
877-504-0233.
•Consumers outside the US and Canada should contact their local retailer or distributor. A list of International distributors may be found at: www.spektrumrc.com/StoreLocator.
•As with all RC aircraft, please check your transmitter and equipment prior to each flight.
•Horizon Hobby and the Spektrum team apologize for this inconvenience.
 樓主| 發表於 2012年3月14日 11:09 PM | 顯示全部樓層
原帖由 myfox 於 2012年3月14日 12:29 AM 發表
不知道是否是以前召回過的問題
及原廠說明
Recently, the Horizon Hobby Se ...
感謝您的資訊.我會反覆測試看看.謝謝
 樓主| 發表於 2012年3月15日 12:58 AM | 顯示全部樓層
不知道是否是以前召回過的問題
及原廠說明
好像真的是前輩您說的這個問題呢!!要送回原廠修理才能解決嗎?
GMT+8, 2026年11月15日 03:33 AM
