樓主: RC99
OS-55 疑問
發表於 2012年1月30日 01:32 PM | 顯示全部樓層
參照原廠資料....
Notes from the Tech Department
This is the O.S. Max .55 AX Aircraft Engine with Muffler.
FEATURES: Same mounting dimensions as the O.S. Max .46 AX
Advanced Bi-Metallic Liner process uses a double layer of plating
material rather than one thick layer. This helps the metal bond to
the cylinder and makes the plating more durable. Also, the plating
process is more consistent, resulting in a more precise fit between
piston and sleeve for better compression and longer life.
Power Box positionable muffler
Angular head design offers increased surface area for better cooling
40J Carburetor with diagonally placed Needle Valve eliminating Remote
Needle Valve placement
Two year limited warranty
INCLUDES: O.S. Max 55 AX ABL Aircraft Engine with E-3070 Muffler, 40J
carburetor, #8 glow plug, illustrated instruction manual, 3.5"
(90mm) long needle valve extension cable and two 3x35mm muffler
screws
REQUIRES: Aircraft blend fuel containing 5%-20% Nitromethane with at least 18%
lubricant
SPECS:    Displacement: .545 cu in (8.93cc)
Bore:   .906"   (23mm)
Stroke: .846" (21.5mm)
Practical RPM: 2,000-17,000
Power Output: 1.75 PS, 1.68 HP/16,000 RPM
Weight: 14.29oz (405g) w/o muffler
18.52oz (525g) w/ muffler
Recommended Props: 12x7-8, 13x6-7
Crankshaft thread size:1/4-28
Distance/remote needle to end of crankshaft:          4.7" (119.4mm)
Distance from center of engine to drive hub:          2.4"  (60.4mm)
Distance from center of engine to end of crankshaft:  3.4"  (87.6mm)
Distance/crankshaft center to muffler exhaust outlet: 3.9" (100.5mm)
Height from crankcase bottom to top of cylinder head: 3.3"  (85.2mm)
Height/crankshaft center to top of cylinder head:     2.6"  (67.4mm)
Width including mounting tabs:                 2" (50.8mm)
Width not including mounting tabs:           1.4" (35.6mm)
Width between mounting holes same side:      .69" (17.5mm)
Width between mounting holes opposite side:  1.7" (43.2mm)
Diameter of muffler body:                    1.5" (38.1mm)
Angle of muffler in relation to engine:               4°
High Speed Needle: 2 turns out from fully closed
Low Speed Neelde:  3mm gap between the needle and spray bar at full
throttle (looking down the neck of the carb)
COMMENTS: Available Pitts Mufflers include BISG4046.
jxs 9/20/06
updated jpg 7/18/07
updt lmm 3/27/09
發表於 2012年2月1日 10:02 PM | 顯示全部樓層
原帖由 jsf123456789 於 2012年1月30日 01:03 PM 發表
新式的化油器附油針鎖到緊,油針會鬆掉落到進氣口中。
這個我最近有學到、要鎖副油針到底時要先把氣門緊閉、要不就如您所說掉下去
GMT+8, 2026年11月11日 06:35 PM
