樓主: dxmaxian
新北 "電電快跑討論區"
發表於 2011年10月18日 02:17 PM | 顯示全部樓層
Hobbywing USB Link setup V1.64 111011
http://www.hobbywing.com/upload/software/Hobbywing_USB_Link_setup_V1.64_111011.rar
CAR_ESC_readme.txt
2011-10-11
Car ESC Database 111011
The Firmware database of the car ESC has been updated to the latest Version 111008.
1.  Two new firmwares named "V3.0_110930_MOD" and "V3.0_110930_STOCK: are available for the following ESC's:
    XERUN-120A (V2.0), XERUN-60A (V2.0), XERUN-120A (V2.1), XERUN-60A (V2.1), Xtreme STOCK
    a)  "V3.0_110930_MOD" is an improved firmware version based on "V3.0_110119_MOD"; the new firmware has been updated to improve the fault tolerance of the signal quality of the Hall sensors within the sensor board of brushless motors.
        The old firmware was found to be too sensitive to any small change of the sensor signal, in turn causing the ESC to frequently switch its running mode from sensored to sensorless. The new firmware is not as sensitive, so the ESC can still operate in sensored mode even if the signal has slight changes in amplitude from small error, that might eventuate this will help Mod motors which have very large current flows which cause the signal within the sensor board of the motor to change frequently causing unnecessary errors .
    b)  "V3.0_110930_STOCK" is a new version based on "V3.0_110211_STOCK", same improvements as above.
2.  New firmware named "V3_508_No Timing" is also available for the JUSTOCK ESC. The improvements are as follows:
    a)  The "Maximum Brake Force" has been increased from 4 options to 8 options for finer adjustment.
    b)  The new firmware has also been improved for fault tolerance of the signal quality of the Hall sensors within the sensor board of the brushless sensored motor*s.
3. New firmware named ※111011_2R§ is available for the following ESC's:
XERUN-80A, XERUN-150A, XERUN-SCT Pro
    a)    "111011_2R" firmware improves the fault tolerance of the signal quality of the Hall sensors within the sensor board of brushless motors.
    b)    The over-heat protection threshold for the ESC is increased to more than 110 Celsius degree, and the over-heat protection function for XERUN-SCT-Pro ESC can be disabled now. (In the old version firmware, the over-heat protection is permanently activated and cannot be disabled by user)
[ 本帖最後由 Daniel206 於 2011年10月18日 02:26 PM 編輯 ]
發表於 2011年10月18日 02:28 PM | 顯示全部樓層
車神Masami vs 老鷹
速度對決 非常好看,一定要看
[ 本帖最後由 Daniel206 於 2011年10月18日 02:43 PM 編輯 ]
發表於 2011年10月18日 03:17 PM | 顯示全部樓層
動物園停車場喔
發表於 2011年10月18日 07:57 PM | 顯示全部樓層
回復 312樓 Daniel206 的帖子
你是要推銷給猩猩還是猴子...
發表於 2011年10月18日 08:59 PM | 顯示全部樓層
請問一下,我的接收器是r603gf,搖控器是2pl,
不知道為什麼今天一打開之後接收器一直亮紅燈,有時是用閃的,有的時候是紅綠燈一起閃,
照說明書重新對頻也沒有反應,請問是什麼問題??
有可能是車用電池沒電的關係嗎?
因為搖控器還有5.3v的電壓,該不會壞掉了吧,剛買沒多久而已~~
發表於 2011年10月18日 11:25 PM | 顯示全部樓層
啊!忘記去跟熊照相了。
GMT+8, 2026年11月27日 09:09 AM
