樓主: kaku130
田宮前置馬達甩尾車
發表於 2010年4月8日 09:17 AM | 顯示全部樓層
已跟正
這是正確消息
不是7月 是8月2010
[ 本帖最後由 JACK.N 於 2010年4月8日 03:30 AM 編輯 ]
發表於 2010年4月8日 11:16 AM | 顯示全部樓層
今過 小弟 (電洽友人)*猴急點.....................
這台確實是田宮反胎甩尾車  (目前增求翻譯)
復連照片
超清晰 3D圖片
一共有 2台 目前找到 我能力果然沒退化
Translation :
The design chassis only for the drift of shipping schedule pre-bid price \49,800 expectation of July of high-end drift chassis kit 【 tentative name 】 appears.
The motor made of aluminum mount is arranged in [roadekki] made of the carbon in [furontomido], and the best weight balance for the drift running is achieved. The maximum feature is “Double upper frame” that vertical (vertical) mount is done. The rigidity in the direction of the pitch (Before and behind) was high, and it was assumed in the direction of the roll (right and left) a flexible chassis characteristic made of the carbon of 2mm thickness.
The steering wheel system that becomes an important factor with the drift chassis improves a right and left tire slice corner, and parallel (parallel) geometry that runs side by side is adopted and the control at counter steering has been improved.
TA05 bulk head, 37T/18T Pulley, [sho-toriba-shiburusasua-mu], and upright TRF416, etc. are choice as for parts up to now, in the touring car with results. A lot of OP parts of the TA05 faction that abundantly becomes complete can be used. The new size front and rear belts, rear belt is × 2, front × 1. Furontoborudefu drive system, Riyadairekutokappuringu, universal shafts around, TRF damper equipped.
It is possible to use it ..[tamiyaguranpuritsu-ringuka-kurasu] (double deck object)…
[Tentative] FF-03PRO Chassis
Mon tentative price will usually June 2010 ¥ 22,800
Brand Batterireiauto employing vertical bite FF enjoy touring car battle
The vertical configuration of the slim chassis battery FF-03PRO is touring a new sensation and can feel the tension gripping battle regulated front race unique side by side and three wide and uniform rule. Specific and tuck-in FF and 4WD driving the car and you can enjoy a different behavior.
The new ball differential capacity development Konpakutogiyabokkusu (inch size ball × 12) equipped. Shotoribashiburusasuamu around the front suspension, glass filled nylon uprights TRF416, IFS and adoption, enables balanced Sasusettingu.
The settings made before or after the Riyasekushon Suspension damper mounting position, the section also altered wheelbase three patterns can be changed to 257,245,233.
TRF damper HB Court, Chitankotopisutonroddo specifications, Arumitanbakkurushafuto (3 × 32mm), aluminum horn Haitorukusaboseiba, Arumipiroboru / ball nut ,06-26T and the underlying high-performance parts Fussokotopinion PRO is sought to enhance the appearance of design.
Tamiya Grand Prix held at Wanmeikukurasu will be world class for the championship.
[ 本帖最後由 JACK.N 於 2010年4月8日 03:21 AM 編輯 ]
田宮3D圖416/TA05?
田宮3D圖416/TA05?
謎樣最新1/8-3D外流照 X3?
謎樣最新1/8-3D外流照 X3?
謎樣最新1/8-3D外流照 X3?
謎樣最新1/8-3D外流照 X3?
最新消息 3D圖 FF-03PRO
最新消息 3D圖 FF-03PRO
發表於 2010年4月8日 11:28 AM | 顯示全部樓層
原帖由 吳瑞政 於 2010/4/7 18:30 發表
OTA那台新車轉向的確令人期待,個人覺得YOKOMO的萬向在加大轉向後的表現良好(我的BD未加工也不會抖動)田宮的萬向就一直很困擾我!也是遲遲不敢拜前置版TA05改套的原因,最希望除新一代TA03F外就是YOKOMO也能早日有前置 ...
你喜歡的 出現喔.................FF-03PRO
發表於 2010年4月8日 11:34 AM | 顯示全部樓層
目前知道價位(暫定)49,800
夭壽比YO牌還敢賺..................................
經過計算後, 49,800 日圓 = 16.591 新台幣
不過...................頂階甩尾車好像都是這價錢 14500- 17000台幣
還是買TA05套件便宜 7000就有
最新出處點續爆  http://www.rceasy.com/
另發現 FF-03aPRO 有用到 相關TB03套件
[ 本帖最後由 JACK.N 於 2010年4月8日 03:43 AM 編輯 ]
發表於 2010年4月8日 12:46 PM | 顯示全部樓層
訂價通常會有打折的我有看到日本購物網商品価格(税込):  \ 30,329         http://www.hs-tamtam.co.jp/item-36742.html
[ 本帖最後由 gary0045 於 2010年4月8日 07:56 PM 編輯 ]
發表於 2010年4月8日 01:49 PM | 顯示全部樓層
原帖由 JACK.N 於 2010年4月8日 11:28 AM 發表
阿政喜歡的是前置馬達的4WD車車
FF-03PRO 應該是繼FF-01、FF-02而出的前驅車車!
GMT+8, 2026年11月6日 07:18 AM
