樓主: 老曹
有效解決經常性摔機的方法
 樓主| 發表於 2009年12月24日 11:11 PM | 顯示全部樓層
我翻譯看看
神 佛 無國界 但是應該都有用....
 樓主| 發表於 2009年12月25日 11:41 AM | 顯示全部樓層
來了.......翻譯版 嘉惠國外飛友
Looks like India this to come out to paste in the cockpit Buddhism protects buddhist law, one of Tianlongbabu “jia Lou Luo king”. Place above sometimes, Buddha goes against has the bird, this is the big huge mythical bird redpoll. The big huge mythical bird redpoll said that Fu Longzhe, for Tibetan Buddhism in important protecting buddhist law, a saying Jin'gang hand Bodhisattva melts presently, reveres for indignation wisdom. Because the big huge mythical bird redpoll may eliminate offends in society god to pray, the God of the Earth and the Burden of sin causes the unknown cause disease with to bond difficultly. Because the big huge mythical bird redpoll can dispatch to eliminate the disaster, eliminates disease, and surrenders each kind of wicked reason, therefore the Tibetan temple or the Tibet others front door, mostly will hang up the big huge mythical bird redpoll law to illuminate, will implore to provide for safely: Lunch. Water. And so on foods all may Lifts 1 fragrance the mouth to read before the loom: The big huge mythical bird redpoll, wilderness ghosts and gods audiences, Luo 剎 the clever child and mother, the manna fills entirely. Letter
Christianity-----Prayer law protection prayer: [name] presents Jesus Christ's name, strives for the lamb valuable blood cover to smudge, in I and my family member [pilotless plane], loves friend, in our industry, and encloses in every direction us is the spirit the thorn fence, the difference sends the angel protect guard to protect us, asks the Holy Ghost to be able the illumination we to have anything greatly hidden, but the present crack, had not allowed that the foe Satan has any attack opportunity on ours body, presents Jesus's name, the pleasant graciousness paste, the paste will wipe on our body, bestows the subordinate day ability and safely on our body. Presents Jesus Christ's famous prayer. Amen! Had free time the addition and subtraction to read usually flies only then quite a while time for 6 hours to be able to fly approximately 5-8 claps to calculate down probably hits the fart about airborne only then the approximately 1 hour to knock the tiger to approximately compose 3 hours to be equal to that rottenly also had 2 hour time ............Everybody does obeisance earnestly reads earnestly prays certainly effectively earnestly ..........Avoids evil influences * avoids evil influences
 樓主| 發表於 2009年12月25日 12:57 PM | 顯示全部樓層
也有阿本仔版
有効アドレス指定の秩序crash' 操縦室の仏教で貼ることを出て来るこのインドのようにs方法見えは仏教の法律、大鵬金翅鳥「jiaルールオ王」のの1を保護する。 上記の場所は時々、仏に対して持っている鳥を、これである大きく巨大な神話上の鳥のredpoll行く。 大きく巨大な神話上の鳥のredpollは重要な保護の仏教の法律のチベットの仏教のためのそのFu Longzheを、格言Jin'言った; 一団手の菩薩は憤りの知恵のために、尊敬する現在溶ける。 redpollが除去するかもしれない大きく巨大な神話上の鳥が社会の神で祈るために地球の神おこり、罪の重荷により未知の原因の病気はとの難しく結ぶので。 従って災害を除去するために大きく巨大な神話上の鳥のredpollが急派でき病気を除去し、そして各種類の悪賢い理由、チベットの寺院またはチベットを他正面玄関手渡すので、大抵大きく巨大な神話上の鳥のredpollの法律を安全にを提供するために懇願する照らすために切る: 昼食。 水。 等食糧はすべて織機の前に上昇1つの芳香口読むかもしれない: ルオの大きく巨大な神話上の鳥のredpoll、荒野の幻影および神の聴衆、剎利発な子供および母は、天恵完全に満ちる。
手紙のキリスト教-----祈りの法律の保護祈り: [名前]イエス・キリストChrist'を示す; sは汚れ、Iおよび私の家族[自動操縦の平面]、愛友人に子ヒツジの貴重な血カバーのために示したりが、私達の企業で努力し、私達によってが精神とげの塀であるあらゆる方向で、相違送る天使を保護する私達を保護するために監視を非常に隠れるために頼むできる聖霊に照明に私達何でも持つために囲む敵Satanに私達のものの攻撃の機会がボディあること現在のひびは、示すJesus'を認めなかった; sは私達の体で、気持が良いgraciousnessののり、のり拭いたり、私達の体で贈与する従属日の能力をおよび安全に示す。 現在イエス・キリストChrist' sの有名な祈り。 アーメン!
發表於 2009年12月29日 12:34 AM | 顯示全部樓層
曹哥這樣可以嗎
 樓主| 發表於 2010年1月1日 03:29 PM | 顯示全部樓層
最好.......
到達飛場時 先以飲料[10元生活.或波蜜]一罐 森永.或其他隨便糖果一包放在遙控工具箱上 再唸一唸 然後開始組機子[約5-10分鐘了] 就可以把供品收一收開始飛了 最安全 我星期四下午去試機 拜完後要開始飛時發現發不動.....搞了很久就不飛了..回家後.才知道化油器連同副油針有問題 然後升降舵伺服器有一顆已經不聽話了 還好沒升空 要不然損失就大了
GMT+8, 2026年11月12日 03:57 AM
