樓主: 阿翰
700e飛行影片來啦
發表於 2009年11月7日 07:07 PM | 顯示全部樓層
回復 6樓 阿翰 的帖子
阿翰~
參考這個~人家飛7分鐘
Scorpion 4035/560kV motor----------馬達
CC 110HV ESC--------------------------電子變速
Hercules BEC------------------------------降壓
FAD 115T Mod 1 main gear----------115T Mod1
Scorpion 10T Mod 1 pinion------------10T馬達齒
X2 6S Turnigy 5000mAh, 35C lipos--2*6S 5000mah電池
G5 Pro Wide Chord 710mm blades--710槳
RJX Flybarless head (modified)--------無平橫翼
Skookum FBL system---------------------無平橫翼電裝
Total weight RTF was 11.4 Lbs.--------總重11.4磅
HS: about 2050 RPM with no load. Under load: down to 1900 RPM.
無載重轉速-2050RPM  載重轉速-1900RPM
My 700e flight time
I have completely finished my 700e conversion and test flown several times to see how it handled and what the final numbers looked like. I did not run any data logs, but, I don't think I need it. I just went by temperature of motor, esc, and lipos. First of all here is my set up:
700 Nitro Kit
Helidirect conversion kit
CC 110HV ESC
Hercules BEC
Skookum FBL system
I am not using the governor yet. I am afraid of using the faulty firmware and burn my expensive ESC.
At the beginning I was flying without the Skookum, but, since I still do a lot of FFF, I did not like the handling of it. It tends to pitch up a lot when in FFF and very unstable hovers when windy. That's why I decided to go with the Skookum. It took care of all the glitches and now I love it.
For each flight I did a series of maneuvers. I am not a hardcore 3D flyer, but, I can pull some maneuvers off. This was my test series: FFF, loops, consecutive flips, consecutive aileron rolls, inverted fight, and a set of tic-tocs. I also did a few punch offs and tried to fly it a little hard. My flight time was 7 minutes.
The verdict
Motor temp: 145 deg F.
ESC temp: 110 deg F.
Lipo temp: 90 deg. F.
Voltage leftover per cell: 3.78V
I can honestly say that I am very happy with this conversion. It has a lot of power and torque. It maneuvers very quickly and it is very efficient. I could probably get another 30sec to a minute more of flying and still have the lipos in a safe zone. But, I rather give it a larger buffer zone. At this point, I don’t miss nitro. Especially the cleaning part and the extra stuff you have to carry around.
GMT+8, 2026年11月15日 12:29 AM
