查看: 670112|回復: 2
【問題】Can the new generation of computer radios do this ?
發表於 2002年12月24日 11:22 PM | 顯示全部樓層 |閱讀模式
Hi Guys,
I am wondering if there are any radio transmitters out there that allows the user to program the mapping between the control slot number and the control function. My old ( 10 years + ) JR computer radios have got the following slot assignment :
Slot 1: Throttle
Slot 2: Aileron
Slot 3: Elevator
Slot 4: Rudder
As I am flying sailplanes, the throttle / gear controls are useless to me but I do need the AUX1 control very often as most of my sailplanes have seperate servo for each aileron. That means the receivers I use must support no less than 6 channels ( Thro, Ail, Elev, Rudd, Gear, AUX1 ) and this requirement has been restricting my choice of receivers.
What I would like to have is a radio transmitter that allows me to swap the AUX1 and throttle control slot at the so that I can use a 4-ch receiver in the following manner :
Slot 1: AUX1
Slot 2: Aileron
Slot 3: Elevator
Slot 4: Rudder
Is this supported by the new generation of computer radio transmitters ?
Thanks in advance ,
Y C Lui
上一篇:【求助】Choice of F3F ships
下一篇:【推薦】斜坡群雄賽
發表於 2003年2月4日 02:59 PM | 顯示全部樓層
y.c. 的問題是常遇到的滑翔機伺服機連動設定
希望兩個副翼連動(Link)又只想用四動接收機
結果油門要改設定成副翼
真不容易
當然頂級的發射機能隨意設定波道就沒問題
若是中級電腦發射機可能會用方向舵來當副翼用
發表於 2003年2月27日 04:35 PM | 顯示全部樓層
CAN YOU DO PROGRAMM MIXING ON YOUR TXMITTER ?    IF SO-------TRY THIS, MIGHT WORK ---MIX THE THE AUX 1 TO THE THROTLLE 100%  --THIS WILL ENABLE THE AUX 1 TO GO WITH THROTTLE .
GMT+8, 2025年12月31日 12:19 PM
