查看: 270|回復: 0
[引擎/動力] 全新 O.S. GT33 飛機用汽油引擎 NTD 12,500
發表於 2025年7月7日 06:37 PM | 顯示全部樓層 |閱讀模式
O.S. GT33 飛機用汽油引擎(38300)
  This is the GT33 Gaso Engine with Muffler and Rear Carburetor
SPECS:    Displacement: 2.013 cu in (32.98cc)
          Bore: 1.417" (36mm)
          Stroke: 1.276 (32.4mm)
          Crankshaft thread size: 5/16-24
          Total Weight: 2.7lbs (1230g)
            Engine, 34.72oz (984g)
            Muffler, 5.65oz (160.5g)
            Ignition: 3.70oz (105.0g)
          RPM Range: 1,800 - 8,000
          Output: 3.9 PS, 3.85 HP/9,000rpm
          Gaso /Oil Mixture: 30:1 - 50:1
            25:1 fuel/oil mixture if brand of oil states 50:1 mix
          Replacement Spark Plug: NGK CM-6 or Denso U20M-U
          Height, Crankshaft Center to Exhaust Outlet: 6.1" (156.1mm)
          Height, Crankshaft Center to Muffler Body: 4.1" (105.4mm)
          Height, Crankshaft Center to Muffler Mounting Holes: 2.1" (54.4mm)
          Height, Crankshaft Center to top of Cylinder Head: 4.3" (109.2mm)
          Length, end of Crankshaft to Carb: 7.7" (196.6mm)
          Length, end of Crankshaft to Backplate: 6.2" (158.9mm)
          Length, end of Crankshaft to Center of Engine: 4.9" (125mm)
          Length, Prop Washer to Center of Engine: 3.3" (84.5mm)
          Length, Prop Washer to Carburetor: 6.1" (156.2mm)
          Length, Prop Washer to Backplate: 4.7" (118.5mm)
          Width, Muffler Body: 4.5" (114mm)
          Width, Crankshaft Center to Exhaust Outlet: 1.2" (31.5mm)
          Cylinder Head Diameter, front to back: 2.5" (62.8mm)
          Cylinder Head Diameter, side to side: 2.6" (66mm)
          Mounting Hole Centers top to bottom: 2.1" (54mm)
          Mounting Hole Centers side to side: 3" (76mm)
上一篇:[售出] 手擲機 含伺服
下一篇:[1090]全新 Spektrum DX3 遙控器加接收
GMT+8, 2025年12月18日 10:19 PM
