查看: 568|回復: 0
[陸/車] [降9000] 1/10拉力跑車一台
發表於 2020年8月8日 08:47 PM | 顯示全部樓層 |閱讀模式
車體有正常使用痕跡,全新車殼全新備料,備品近一車份,當時全部購入已超過2萬,(拆接收無控),新北市新莊區可相約看車。
Traxxas 1/10 Rally Brushless 4WD
Vehicle Specification:
Length: 552mm
Height: 206mm
Weight: 2780g
Wheelbase: 324mm
Track Front and Rear: 297mm
Center Ground Clearance: 21mm
Overall Drive Ratio: 11.82 (stock, out-of-box)
Tires: Officially-Licensed BFGoodrich? Rally Gravel 2.2 Pre-Glued with Foam Inserts
Tires Diameter: 102mm
Wheels: 2.2 12-Spoke Rally Replica (White, Green, or Orange)
Wheel Diameter: 54mm (Outer) 76mm (Inner)
Differential Type: Hardened Steel Bevel, Sealed, Limited Slip
Gear Pitch: 32
Chassis Structure/Material: Molded Tub / Nylon Composite
Drive System: Shaft-Driven, Direct Drive 4WD
Steering: Dual-Bellcrank with Integrated Servo Saver
上一篇:[降2500] HYPERRION EOS720I DUO
下一篇:[2000]六角形焚火台
GMT+8, 2025年10月24日 06:19 PM
