本帖最後由 jrwei 於 2017年12月26日 09:25 AM 編輯
VOLANTEX RACENT HURRICANE SAIL YACHT BOAT 1M RTR V791-2
Some say that a sailboat is the only way to truly enjoy the experience of being on the water. Who are we to argue with those sentiments, as nothing is more rewarding than preparing to navigate your r/c yacht in the breeze in true classic yachting style.
The Hurricane is a large 1m length sailboat and measuring in at 213cm tall (tip to balast) it is a impressive model. Coming mostly factory assembled, the blow moulded ABS hull features a sealed radio box that houses a 2.4ghz radio system, winch and rudder servo and Li-ion receiver battery.
Most of the rigging is completed at the factory, leaving final assembly and mounting of the printed nylon heavy-duty sails a relatively quick affair.
If you are looking for the ultimate r/c sailing experience, sail with the Hurricane.
FEATURES & SPECIFICATIONS
Ready-To-Run
2.4ghz radio
Rudder Servo
7.4V 850mAh Li-ion Receiver Battery
USB Charger
Printed nylon sail
Hull Length: 995mm
Beam (Width): 220mm
Height from bottom of hull: 790mm
Height from bottom of ballast: 2130mm
Weight: 3.15kg
Hull Material: ABS Plastic
Ballast Material: Iron
Ballast Weight: 1.7kg
Jib - 2500 sq cm
Main - 3550 sq cm
Total - 6050 sq cm
Please Note: This is sold in RTS format and requires 4 x AA batteries.
VLX-V791.zip
(1.22 MB, 下載次數: 2109)
