查看: 715|回復: 1
[完成] [2000] EACHINE LCD5802D + 平板/蘑菇天線
發表於 2017年12月6日 11:13 PM | 顯示全部樓層 |閱讀模式
本帖最後由 a1980201 於 2017年12月7日 08:00 PM 編輯
9成9新,40ch,雙天線接收,DVR
加附1平板、1蘑菇天線
Description:
Brand Name: Eachine
Item Name: LCD5802D Monitor
Built-in 5.8Ghz Dual diversity receiver automatically for best reception
Built-in 2CH 5.8Ghz AV output and 1CH AV input
Built-in high performance Li-POLYMER Battery:2000mAH/7.4V
Work status OSD display :RSSI indication ; Battery indicator;Channel indication
A key to automatic signal search
Support Chinese and English menu
Format: JPEG, AVI
Screen size:7”
Screen type:TFT LCD Screen/long life, LED backlight
Resolution: 800*480
Brightness:600cd/m2
View Angle:140/120degree (Horizontal/Vertical)
Size:180mm x 120mm x 25mm(Note:Sunshield height:110mm)
Working Voltage:DC 7~16V
Power Consumption:max 650 mA @12V
Battery charging current :850mA @12V ( max )
Working temperature:-10℃~+ 65 ℃
Connectors:RP-SMA female(outer needle)
Antennas Connectors:RP-SMA male (inner hole)
Support up to 32G , C10 SD Card.
Features:
With DVR function
Built-in Dual Receiver for best reception
Dual buffered AV outputs
Not affect by 2.4GHz R/C Radios
AV Receiver with Diversity inputs
Small, light weight, durable
5 Bands and total 40 Channels
Built-in battery , easy to carry and outdoor use
A key to automatic signal search,Simple operation
Work status OSD display:Always be aware of the device working condition.
Notice: It can't receive 2 different channels at the same time
Band and Channel selection
     CH
CH 1
CH 2
CH 3
CH 4
CH 5
CH 6
CH 7
CH 8
GROUP
A
5865 MHZ
5845 MHZ
5825 MHZ
5805 MHZ
5785 MHZ
5765 MHZ
5745 MHZ
5725 MHZ
B
5733 MHZ
5752 MHZ
5771 MHZ
5790 MHZ
5809 MHZ
5828 MHZ
5847 MHZ
5866 MHZ
C
5705 MHZ
5685 MHZ
5665 MHZ
5645 MHZ
5885 MHZ
5905 MHZ
5925 MHZ
5945 MHZ
D
5740 MHZ
5760 MHZ
5780 MHZ
5800 MHZ
5820 MHZ
5840 MHZ
5860 MHZ
5880 MHZ
R
5658 MHZ
5695 MHZ
5732 MHZ
5769 MHZ
5806 MHZ
5843 MHZ
5880 MHZ
5917 MHZ
Package Included:
1 x 7" LCD Screen Receiver Monitor with built in Rechargable Battery
2 x 5.8G Antenna
1 x AV Cable
1 x Charger
上一篇:誠徵Frsky 發射 接收
下一篇:售1/8蛇仔油車已售
發表於 2017年12月6日 11:36 PM 來自手機 | 顯示全部樓層
收請PM
GMT+8, 2025年10月31日 04:38 PM
