查看: 844|回復: 8
[完成] (2880含運)Eachine Micro Skyhunter 780mm Wingspan EPO FPV PNP With Camera
發表於 2017年4月11日 05:34 PM | 顯示全部樓層 |閱讀模式
本帖最後由 Mirage2000 於 2017年4月13日 09:34 AM 編輯
只有一台,包含圖傳鏡頭,簡單組裝,
輕鬆好飛,玩第一人稱飛行不二機選。
產品規格:
Brand Name: Eachine
Item Name: Micro Skyhunter
Wingspan: 780mm (31")
Length: 540mm (21")
Weight: 230g (without battery)
Color: White
Material: EPO
CG:
4cm from the wing leading edge(There is a convex point under the wing,that is the CG)
Camera: Eachine EF-01 AIO FPV camera
ESC: 20A 2-3s with XT60 connector
Motor: Eachine 2204 2300KV
Motor MAX Thrust:440g
Motor Weight: 25g
Motor Shaft Diameter: 3mm
Propeller: 6x3, but works well with most 5-6" multirotor props, even quad blade.
Servos: 3x 9 gram
Recommended AUW: Under 375g
Specification Of Eachine EF-01 Camera:
Brand NameEachine
Item nameEF-01 AIO FPV Camera
FPV CameraSensor: 1/3 "CMOS
Lens: M8 800TVL Lens
Angle: 150 ° FOV horizontal viewing angle of 170 ° DFOV diagonal perspective
Format: NTSC / PAL (switchable)
Resolution: NTSC: 960X480/ PAL:960X480
Power consumption: 380mA @ 3.7V
Power: 3.6-5.5V
Lens Mirror Diameter: 2.1mm IR coated FOV150 (horizontal)
Plug: with a new plug,directly supplied power by receiver.
TransmitterSupport video format: NTSC / PAL
Output Impedance: 75 Ohm
Output signal strength: 23 ~ 24dBm
Output Power: 25mW
Wireless Channel: 40CH
Antenna: RHCP circular polarization clover leaf antenna
Operating voltage: 3.6V ~ 5.5V
Current: 100mA
Audio carrier: 6.5MHz
Button function
Short press (Apr. 1 sec or less): Change channels 1-8
Long press (More than 1.5 sec): Change bands A-B-E-F-R
Long + press (More than 3 sec): Change NTSC/PAL system
NTSC or PAL (selectable; Blue LED on= NTSC; Blue LED off=PAL)
BodyWeight: 8g
Size: 26x20x18mm (without antenna)
產品圖片:
7b2bee3d-9f4f-42d7-88ad-50fc846a8fad.jpg f60423ea-ac89-482d-9692-5b23b8efedb2.jpg 5275b615-8761-46fe-8422-ec18f1ce6633.jpg
開箱影片
飛行影片
[巳售完]售x營伺服器
[17500]Pilot 88"(2.24M)50cc 至60cc
發表於 2017年4月11日 05:59 PM 來自手機 | 顯示全部樓層
這個接收 可以多遠
上述內容是原廠資料提供你參考,3q  詳情 回復 發表於 2017年4月12日 08:55 AM
 樓主| 發表於 2017年4月12日 08:55 AM | 顯示全部樓層
上述內容是原廠資料提供你參考,3q
發表於 2017年4月12日 09:39 AM | 顯示全部樓層
先排隊, 請收PM, 謝謝!
  發表於 2017年4月12日 03:09 PM
發表於 2017年4月12日 01:08 PM | 顯示全部樓層
排 確定要
  發表於 2017年4月12日 02:04 PM
GMT+8, 2026年2月25日 07:16 AM
