查看: 2315|回復: 7
[完成] 輝哥[2000元]300W充電器20A +分壓板
發表於 2017年1月10日 12:09 PM | 顯示全部樓層 |閱讀模式
本帖最後由 rzx135sp 於 2017年1月10日 08:51 PM 編輯
操作超簡單  可量內阻 !! 可量內阻 !!  可量內阻 !!
狀況不差的電池 充電很快  也可以外接控制大功率放電達500W
狀況非常良好  狠新  不是外場操爛過的充電器
+ 一組 分壓板
以下是 這台相關數據
Big power in a small package! the Turnigy Reaktor 300W charger is one of the most powerful chargers we have ever seen for its size. This high power balancing charger/discharger can provide up to 20A charge rates and handle up to 6S Li-poly/LiFe or 17S NiCd/NiMH accurately. Not only does the Reaktor 300W offer a super high charge rate capability, it also boasts great features such as storage charging, cyclic charging/discharging, 10 charge parameter memory and high power balancer.
The Turnigy Reaktor 300W is an all-in-one power house charging solution for your R/C models' batteries.
Features:
‧ Microprocessor controlled
‧ Delta-peak sensitivity (NiMH/NiCd)
‧ Individual cell balancing charge & discharge
‧ Li-ion, Li-poly and LiFe capable
‧ Ni-Cd and NiMH capable
‧ High-power and high-performance circuit
‧ Store function, allows safe storage current
‧ Data storage (Store up to 10 packs in memory)
‧ Cyclic charging/discharging
Specs:
Input voltage: 11~28V DC
Charge current: 0.1~20A
Discharge current: 0.1~20A
Maximum charge capacity: 300W
Maximum discharge capacity: 20W
Maximum regenerative discharge power capacity: 300W
Maximum external discharge power capacity: 500W@25V/20A
Current drain for balancing Li-po: 350mAh/cell
Lithium (Li-poly/LiIo/LiFe) battery cell count: 1~6 series
NiCd/NiMH battery cell count: 1~17 series
Pb battery voltage: 2~24V
Battery setup memories: 10
Intelligent temperature control: Yes
Weight: 350g
Dimensions: 140x95x27mm
可以比較看看下面
這是206B 相關數據
< iCharger 206B 規格 >
輸入電壓:10 – 28.0 VDC
充電電流:0.05 – 20.0 A
放電電流:0.05 – 20.0 A
最大充電容量:300W @ 輸入18V 以上(約220W@輸入12V)
最大放電容量:20W
最大回充放電容量:300W
最大外接負載放電容量:500W @ 25V/20A
平衡電壓:< 350 mA
平衡準確度:< 10 mA
鋰電可充芯數:1 – 6 S (非平衡充LiFe可到8S)
鎳氫/鎳鎘可充芯數:1 – 17 S
鉛酸電池可充芯數: 1- 12 S (2 – 24V)
紀錄檔案存量:16Mbit (36小時)
電池設定檔案數:10
智慧型溫度控制:有
電腦連線:USB port
重量:350公克
尺寸:134 X 83 X 25 mm
歡迎面交測試 0987254377 台南 陳先生(如沒接電話 請留言)
可以外接控制大功率放電500W
IOM
  發表於 2017年1月10日 06:32 PM
上一篇:雷虎soaring star (已售出)
下一篇:徵B6 MINI
發表於 2017年1月10日 02:28 PM | 顯示全部樓層
IOM
  發表於 2017年1月10日 05:51 PM
發表於 2017年1月10日 02:41 PM | 顯示全部樓層
IOM
GMT+8, 2025年12月26日 05:07 AM
