本帖最後由 chaohsinming 於 2016年4月28日 01:28 PM 編輯
含運6000元 西盛可面交
全新800級 附5mm金插(公)3支
天蠍 Scorpion HK-5035-410KV
實體照
下圖為借網圖
Specifications
| Stator Diameter | 50 mm (1.56 in) | | Stator Thickness | 35 mm (1.37 in) | | No. of Stator Arms | 12 | | Magnet Poles | 10 | | Motor Wind | 9 Turn Delta | | Motor Wire | 24-Strand 0.33 mm | | Motor Kv | 410KV RPM / Volt | | No-Load Current (Io/10V) | 2.12 Amps | | Motor Resistance (Rm) | 0.014 Ohms | | Max Continuous Current | 105 Amps | | Max Continuous Power | 5100 Watts | | Weight | 670 Grams (23.63 oz) | | Outside Diameter | 61.0 mm (2.4 in) | | Shaft Diameter | 5.98 mm (0.23 in) | | Body Length | 66.0 mm (2.59 in) | | Overall Shaft Length | 116.5 mm (4.59 in) | | Max Lipo Cell | 14s | | Peak Current | 145A (5 seconds) | | Peal Power | 7000 Watts (5 seconds) | | Motor Timing | 5deg | | Drive Frequency | 8kHz |
▼ 下一篇:PL6+明緯1000W電供[800含運]JR接收 35MHz RS10DS▲ 上一篇:
