查看: 9536|回復: 75
★★★KEEL-270 FPV穿越機 到手可飛
發表於 2016年1月28日 08:48 PM | 顯示全部樓層 |閱讀模式
本帖最後由 DKCK 於 2016年1月28日 08:58 PM 編輯
更多商品,請至<DKCK專區按我進入>參觀
Horizon商品,賣場沒有現貨的,皆可代訂,歡迎詢問喔
BLADE,SPEKTRUM,E-fliterc,ParkZone,HobbyZone...等眾多品牌
MICROHELI/LYNX 改裝套件
各式大小四軸套機/單機
各式FPV方案/代裝機
Parrot 派諾特系列商品
HiSky系列商品
@@最新KEEL270 組裝OK,到手可飛
@@藍/橘/黑/銀四色外殼可選
@@已組裝整機版:含整機+圖傳+鏡頭(需自備接收+遙控器+電池)
@@已組裝含控RTF版:整機版+DEVO10遙控器+RX1002接收+1800mAh電池
@@或可選擇DSM2/X接收或其他接收安裝
@@以上不含mobius錄影機
FPV 套裝
電機:2204L 2400KV X4
電調:oneshot125 12A X4
CC3D飛控系統 X1
UBES 5V 電源模塊 X1
6045高速正反槳 X4
CCD 700線像頭 X1
600MW 圖傳 X1
KEEL-270碳纖機架(含頭罩)  X1
Description:
Brand: Lisam
Model: KEEL-270
Wheelbase: 270mm
Weight: 145g
Material: 3k Carbon Fiber
Size: 224 x 211 x 85mm
Motor:
Model: 2204L
KV (rpm / v): 2300
Batteries number (cell): 2-4S
Weight: 21g
Height: 34.6mm
Diameter: 28mm
Propeller Aperture: 5mm
Lisam oneshot125  ESC 12A:
Continuous operating current: 12A
Instantaneous current: 20A (5 seconds)
Number lithium applicable section: 2-4S
Size: 31 x 15 x 5mm
Weight (with cord): 7.4g
BEC
Can Programming: Yes
Flight Controller:
Flight Control Model: MICRO CC3D
Size: 44 x 20 x 13mm
Weight: 6.7g
UBEC 5V power supply module:
Input voltage 4.5V ~ 28V
Output voltage 0.8V ~ 20V
Output current 3A (maximum)
Conversion efficiency of 96% (maximum)
Output Ripple <30mV
Switching frequency 1.5MHz (highest)
Operating temperature -45 ℃ ~ + 85 ℃
Size 22mm x 17mm x 4mm
Propeller:
5030 5045 6030 6045 high-speed Propellers
Camera:
Item Name: 700TVL Camera
Degree: 120
Shot: 2.8mm
Lens Type: Wide Angle
Size: 32mm x 32mm
AV Transmitter:
Frequency: 5.8GHz
Channel: 40
TX Poweer: 600mW
With Antenna
A key control, two-color LED status display
Features:
Body bottom with PCB scoreboard
PCB has TX60 battery port welding, soldering just need TX60 battery terminals fixed
Package Included:
1 x KEEL-270 Frame Kit
4 x 2204L 2400KV Motor
4 x Oneshot125 12A ESC
1 x Lisam 600mw AV Transmitter with antenna
1 x 700TVL CMOS Camera
1 x CC3D flight control system
1 x UBEC 5V power supply module
4 x 6045 high-speed Propeller
1 x Amass TX60
una
  發表於 2016年7月18日 08:41 AM
上一篇:★★★HCP60 全世界最小6動機 3D/6G隨意切換
下一篇:★★★BLADE 270 CFX BNF BASIC
 樓主| 發表於 2016年1月28日 08:51 PM | 顯示全部樓層
評分
參與人數 1積分 +3 收起 理由
yehmark + 3 謝謝您的分享!
查看全部評分
發表於 2016年1月28日 09:12 PM | 顯示全部樓層
pm..............
給你囉  詳情 回復 發表於 2016年1月28日 09:15 PM
 樓主| 發表於 2016年1月28日 09:15 PM | 顯示全部樓層
發表於 2016年1月28日 10:08 PM | 顯示全部樓層
想知道價格............
給你囉  詳情 回復 發表於 2016年1月28日 10:14 PM
 樓主| 發表於 2016年1月28日 10:14 PM | 顯示全部樓層
wstjw 發表於 2016年1月28日 10:08 PM
想知道價格............
給你囉
GMT+8, 2025年12月27日 09:22 PM
