查看: 2005|回復: 2
★★★年終特價~可倒飛四軸BLADE NANO QX 3D BNF
發表於 2015年12月5日 03:00 PM | 顯示全部樓層 |閱讀模式
更多商品,請至<DKCK專區按我進入>參觀
Horizon商品,賣場沒有現貨的,皆可代訂,歡迎詢問喔
BLADE,SPEKTRUM,E-fliterc,ParkZone,HobbyZone...等眾多品牌
MICROHELI/LYNX 改裝套件
各式大小四軸套機/單機
各式FPV方案/代裝機
Parrot 派諾特系列商品
HiSky系列商品
BNF版:單機*1,1S 200mAh 30C 鋰電*1,USB充電器*1,備用槳1套4支
有需要者,可至露X 搜尋 " DKCK 一鍵倒飛 " 下標,超商取貨付款免運=2000元
更多照片/設定請進
真正可倒飛小四軸
不是只能翻滾喔
拿來練倒飛的聖品只要是對應DSM2/DSMX的控就可,DEVO刷萬用控也可喔
@@新手穩定模式練練航道,一鍵翻滾
@@中手EVO模式,一鍵倒飛,練練倒飛航道
@@老手3D模式,有正負P(<50%馬達會逆轉)
@@7mm*16mm馬達,軸心0.8mm
原廠英文說明書
更多設定說明請進
  • Fully-assembled, no building necessary
  • SAFE® technology makes it easy to enjoy RC flight and aerobatics
  • Flip 180–360° in any direction at the press of a button
  • Fly inverted without having to learn complex control input
  • Colorful LEDs and high-contrast body help maintain orientation
  • Tough yet lightweight composite airframe with durable blade guards
  • Reversible coreless motors deliver positive and negative thrust
  • Ultra micro 4-in-1 DSMX® receiver/ESCs/mixer/SAFE sensor unit
  • Replacement rotor blades (included) keep you flying
  • E-flite® 200mAh 1S 3.7V 30C Li-Po flight battery included
  • Compact USB Li-Po flight battery charger included
  • SAFE®技術,讓您輕鬆享受RC飛行和特技飛行
  • 翻轉在任何方向180-360°在按下一個按鈕(使用RTF的遙控器)
  • 無需學習複雜的控制輸入飛倒
  • 七彩LED和高對比度的身體幫助保持方向
  • 堅韌而輕便的複合材料機體採用耐用的槳片
  • 可逆的無芯馬達提供正負逆衝
  • 超微型4合1DSMX®接收器/混頻器/ SAFE傳感器單元
  • 包括可更換槳片
  • 包括E-flite®200MAH 1S 3.7V 30C鋰聚合物電池
  • 包括USB鋰聚合物飛行電池充電器
The ultra micro Blade® Nano QX 3D quadcopter breaks the barriers of maneuverability by making high-speed flips, hair-pin turns and inverted flight simple to perform. Intuitive SAFE™ technology delivers smooth flight, self-leveling and multiple flight modes. Clever design and reverse motor technology allows the Nano QX 3D to be strong and light, so there’s almost no penalty for error if you practice aerobatics over plush carpet or soft grass—you’ll have a blast!
Aerobatics Made Easy
SAFE® (Sensor Assisted Flight Envelope) technology is a revolutionary electronic flight envelope protection system. This intuitive technology allows the Nano QX 3D to battle windy conditions so that performance is consistently smooth. Regardless of pilot skill level, there’s a flight mode available to suit the way you want to fly instantly.
Stability Mode
Pitch and roll limits are locked to offer a limited flight envelope while electronic self-leveling offers positive stability the instant you release the sticks. You can also flip 360° in any direction at the press of a button.
EVO Mode
Evolve your flight routine at the press of a button with the ability to flip 180-degrees from upright to inverted and back again with ease. The flight controls stay the same, regardless of orientation. Self-leveling and flight envelope limits are maintained.
3D Agility Mode
A true 3D flying experience that offers full-range maneuverability with no self-leveling assistance. When flying upright in this mode, 0–50% throttle is negative thrust and 51–100% is positive thrust.
超微型Blade® NANO QX 3D四軸飛行器通過高速突破操作性的障礙翻轉,轉彎和倒飛簡單的執行。直觀SAFE™技術提供流暢的飛行,自平和多個飛行模式。
巧妙的設計和反向電機技術使NANO QX 3D是強,重量輕
特技飛行SAFE®(輔助傳感器)技術是一個革命性的電子飛行保護系統。這種直觀的技術使NANO QX 3D戰鬥大風的條件下,這樣的表現一直平穩。
穩定模式
俯仰和橫滾限制被鎖定,提供有限的飛行,而電子自平提供積極的穩定。您也可以翻轉在任何方向360°在按下一個按鈕。
EVO模式
進化你的飛行程序,按下一個按鈕,與翻轉180度直立輕鬆倒,然後再返回的能力。飛行控制保持不變,而不管方向如何。自平和飛行範圍保持不變。
3D敏捷模式
真正的3D飛行經驗,提供全方位的機動性,沒有自平援助。在此模式下飛翔,0-50%油門是負的推力和51-100%的正面推力。
  發表於 2015年12月5日 03:18 PM
上一篇:★★★更新~BLADE 230S 原廠釋放升級韌體,可免費回娘家升級
下一篇:★★★微型130級4軸穿越FPV~黑小四BSF-130
發表於 2015年12月9日 10:59 AM | 顯示全部樓層
GMT+8, 2025年12月27日 03:34 PM
