本帖最後由 dw2012 於 2015年7月9日 07:22 AM 編輯
RC4WD TF2 SWB 空車架 (不含車殼) 此車架特別設計給 Tamiya Jeep Wrangler Body 使用
Realistic Billet Aluminum Ladder Frame Chassis "SWB"
R3 Single Speed Transmission
Center Mounted Realistic 4x4 Transfer Case
Yota II Ultimate Scale Cast Axle
True to Scale Leaf Spring Suspension
5 Lug Wagon 1.9 Steel Stamped Beadlock Wheels (Black)
Mud Thrashers 1.9 Scale Tires
Realistic Bumpers and Skid Plate
Chassis Mounted Steering Servo
RC4WD Scale Shock Absorbers
Plastic Rod Ends
Full Ball Bearings
車架細部規格如下:
All New Hammer Transfer Case
Ratio - 1.47:1
Gears - Wide 32P steel gears
All New R3 Single Speed Transmission
Ratio: 1.78:1
Pinion/spur 14/64 = 4.57:1
Cast Yota 2 Axles
Ratio: 15/40 = 2.67:1
Width at hex: 176.5mm
Trailfinder 2 SWB Chassis
Features - Billet aluminum construction Adjustable shock hoops
Driveshafts
RC4WD Punisher Metal Driveshafts
Heavy duty steel construction
Wheels
Type: 1.9 5 lug Wagon Wheels
Hub: Pin type
Width: 25mm
Back spacing: 11mm
TF2 SWB Dimensions
Wheels Base: 9.9in / 242mm
Width: 8.3in / 211mm
Height: 5.55in / 141mm
Ground Clearance: 2.3in / 58.5mm
Overall Length: 15.31in / 389mm
Weight: 62.1oz / 1.76kg
RC4WD TF2 SWB 空車架 NT$11990 含運
入門級電裝套餐:
RC4WD TF2 SWB 空車架
好盈 QUICKRUN-WP 1060 防水有刷電變
CROSS 35T 有刷馬達
KKPIT S16 入門級金屬齒數位防潑水伺服機
這樣一套只要 NT$13180 含運
另有高階電裝套餐:
RC4WD TF2 SWB 空車架
Castle Creations SV3 防水有刷/無刷電變
CROSS 35T 有刷馬達
KKPIT LV-1323 全金屬數位防潑水伺服機
這樣一套只要 NT$15280 含運
上一篇:[899起]Futaba R2106GF / R2006GS / R2008SB下一篇:[2368 含運] RC4WD 1/10 攀岩車用絞盤套裝
