查看: 6758|回復: 46
★★★Vortex Race Quad 5.8 GHz 350mW,這個猛
發表於 2015年6月28日 05:19 PM | 顯示全部樓層 |閱讀模式
本帖最後由 DKCK 於 2015年6月28日 05:22 PM 編輯
更多商品,請至<DKCK專區按我進入>參觀
Horizon商品,賣場沒有現貨的,皆可代訂,歡迎詢問喔
BLADE,SPEKTRUM,E-fliterc,ParkZone,HobbyZone...等眾多品牌
MICROHELI/LYNX 改裝套件
各式大小四軸套機/單機
各式FPV方案/代裝機
Parrot 派諾特系列商品
HiSky系列商品
這台猛了
285mm軸距機身
免拆螺絲可摺疊機架
T-motor 馬達
肥鯊天線
350mW 40ch 5.8G發射
肥鯊600TVL鏡頭
12A電變,上ONESHOT125
可安裝狗3.4, MOBIUS雲台
強大OSD介面
可上CLEANFLIGHT調參
可上3S/4S電池
整機重量350g,不含電池/錄影機
Retail Price ($USD), Race Motors: $449.00Initial Release Date: April 2015 Weight: ~350g without battery, or HD cameraPower Requirements: 3s-4s LiPo (typical)ESCs: Full Custom, 12A cont. 16A peak, rotorSENSE, OneShot125Flight Camera: FatShark 600TVL CMOS (std), FatShark 700TVL CMOS, and 900TVL CCD optionalHD Camera: GoPro Hero, Hero 3/4  (Optional power from onboard BEC), Mobius, RuncamReceiver Compatibility: CPPM Input, with S-Bus, and Spektrum™ Satellite converter cables optionalFlight Time: Highly dependent upon battery, and flying style
  • 285-sized foldable Mini-Quad
  • Carbon Fiber and custom injected plastic design
  • Tiltable, Vibration-free Camera mount
  • Integrated Flight Controlle and full-graphic On-screen Display
  • Integrated 40-channel NexWaveRF 5.8GHz Video Transmitter
  • Flexible Camera Mounting Options
The ImmersionRC team set out to create a unique foldable mini-quad frame and the result is the Vortex Race Quad. The Vortex includes an integrated full-graphic OSD (on-screen display) and custom 5.8GHz video transmitter which feeds your video signal to headsets and monitors without interfering with 2.4GHz transmitter signals. All that is needed to complete the package is a receiver and a battery. Everything else is included, from the SpiroNET Tx antenna, to the props.
The integrated flight controller, with 3 axis Gyro, 3 axis Accelerometer, and barometer, is pre-programmed with CleanFlight, and is future-proof, supporting future updates via a USB port on the back of the quad for programming and updates. A set of 8 24-bit RGB LEDs sit on the tail of the Vortex, sandwiched safely between the upper, and lower frame plates. These LEDs are controlled by a dedicated 32-bit ARM processor.
The flexible Vortex camera mount supports both a flight cam and an HD camera such as a GoPro or Mobius. The flight cam is protected from impacts and is suspended from a vibration-dampened carbon-fiber plate. An adjustable bracket allows the camera to be tilted to ensure a good forward view during high-speed racing. A 3A switching regulator allows any HD camera to be powered from the flight pack, allowing unnecessary camera batteries to be left at home.
An on-board NexWaveRF 5.8GHz video transmitter, with 40 channel support, ensures compatibility with any 5.8Ghz A/V receiver on the market. ImmersionRC’s exclusive RaceBand allows 8 pilots to fly together. The on-board OSD allows video transmitter channels to be chosen using the R/C transmitter and is compatible with all ImmersionRC/FatShark, Boscam, Team Black-Sheep, DJI, and ImmersionRC RaceBand channels.
The Vortex includes tuning parameters from Pro-Racers right in the box. Just select the racer, prop size, HD camera choice along with other perameters and the Vortex OSD will setup the flight controller for you. Custom 12A ESCs (16A Peak) with OneShot125 and regenerative braking for crisp-responsive flight using CleanFlight. A 32-bit ARM processor runs each ESC ensuring plenty of processing power to drive even the most fussy brushless motors. The ESCs are so thin that they fit completely into the arm tubes, protected from the elements and the occasional passing tree.
An on-board 3 Amp, 5V switching regulator keeps the electronics fed with a clean supply, with enough left over to power a GoPro, Mobius, or any other camera which requires a clean 5V supply.
An on-board full-graphic OSD provides in-flight updates of critical parameters and sports a menu which allows all options to be programmed in the field using the R/C Tx, and a set of goggles, or an LCD screen.
A real-time interface with the flight controller enables artificial horizons, F-18 style displays, and exchange of flight parameters.
上一篇:★★★ 到貨~Chroma w/1080p CGo2+, ST-10+ 第一批享優惠
下一篇:★★★HiSKY HMX280四軸穿越機 RTF/BNF 預購中
 樓主| 發表於 2015年6月28日 05:21 PM | 顯示全部樓層
本帖最後由 DKCK 於 2015年6月30日 04:13 PM 編輯
請PM 含控 到手可飛 價格 謝謝  詳情 回復 發表於 2015年7月2日 08:33 AM
發表於 2015年6月28日 08:16 PM | 顯示全部樓層
你好~請PM價格  謝謝
發表於 2015年6月28日 09:57 PM | 顯示全部樓層
請PM不含控 到手可飛價格
發表於 2015年6月28日 10:58 PM | 顯示全部樓層
請pm價格?
發表於 2015年6月28日 11:31 PM | 顯示全部樓層
漂亮....請pm價格?
以上都給囉  詳情 回復 發表於 2015年6月29日 01:16 AM
GMT+8, 2025年12月7日 02:21 AM
